landscapeman
- Joined
- Jan 8, 2009
I can not seem to install a LaserJet 3015 using the USB cable. It doesn't seem to find the printer. I can install network printers. Any Ideas? Thanks
The HP laser is fully supported by 7. It should theoretically automatically install when you plug in. But if it it not doing this, try the Add a printer" dialogue and use "add a local printer" and then create a "create a new port2. Give it a meaningful name. You will then get the full list of appropriate drivers that can be installed from within 7.
