Windows 10 USB Problem
svberg
Hi.
Been struggeling with this for weeks.
Device manager do not detect new devices.
I'm also not able to uninstall any of the universal USB controllers.
Have tried to boot without any USB devies exept keyboard and mouse, but usb is still not working correctly.
I have win10 with latest update, ASUS ROG maximus XI extreme with latest bios.
How do I remove all the USB drivers to get a clean install from latest drivers.?
Also, if I try a "scan for new devices" in the device manager, the device manager stop working, and have to be terminated with Task Manager..
Hope for some help...
regards svein
Neemobeer
Windows Forum Team
Sometimes simply removing the USB hub devices, or root hub and rebooting can solve issues like this (you may need to power cycle since usb devices will all stop working) or rolling back to a system restore point can help correct issues.
svberg
Hi.
I cannot uninstall or disable any device under Universal Serial Bus controllers. The device manager only stop working..
regards
JandN2639
Well-Known Member
How old is your computer? What brand and model? Are there other problems?
Sent from my iPhone using Tapatalk
svberg
Its only a few month old.
Based as statet on ASUS motherboard.
No, I only have problem with USB devices. Also my two usb printers are not well.
But right after reboot I'm able to print on one of them. (Brother laser)
regards svein
