B barsim Active Member Joined Nov 14, 2012 Nov 14, 2012 #1 Hi, My OS is XP Pro 32-bit. Using Easy Transfer 32-bit saved selected files to external HD. After installing Win 7 64-bit, can I use the resident Easy Transfer to reapply/import the earlier saved files? Thank you barsim
Saltgrass Excellent Member Microsoft Community Contributor Joined Oct 16, 2009 Nov 15, 2012 #2 It is supposed to work as you suggest, have you tried? Easy Transfer may not move programs and such, but should move personal data.
