Windows 7 Various BSOD errors
Entheogenic
I have been having various BSODs, can anyone help me out? Info is attached.
Your system has 101 updates since SP1 - most systems have 130 to 140. This doesn't mean that you're missing any, but it's a good reason to check in order to be sure. Please visit Windows Update and get ALL available updates.
Your C: drive has under 5% free space - that's most likely causing performance issues with your system. Please free up 15% free space on it as soon as you can. The D: drive has about 10% free space, which causes less issues than the lower values - but still does impact your performance. Please free up 15% free space on ALL of your drives. Windows uses this space to perform file operations.
Although I wasn't able to read the MSINFO32 report in great detail, I find that you have a lot of hard drives. What is...
Although I wasn't able to read the MSINFO32 report in great detail, I find that you have a lot of hard drives. What is the make/model/and wattage of your Power Supply?
We've seen a number of BSOD issues with SSD's. Here's the information that I've compiled so far:
There's not a whole bunch available to test SSD's. The "easiest" test is to remove the SSD, install a platter-based hard drive, install Windows and test for stability that way.
Here's some suggestions:
- Update the SSD's firmware to the latest available version (VERY IMPORTANT!!!)
- Update the motherboard controllers drivers to the latest available version from the controller manufacturer (NOT the mobo manufacturer unless you can't find any on the controller manufacturer's website)
- Slow the memory (RAM) down to the next slower speed (I've only seen one person who claimed that this worked for them).
- Use any manufacturer's utilities that you may have. If you don't have any, then try this free one (I haven't used it myself): Crystal Dew World
- Update chipset and storage controller drivers to the latest available from the manufacturer of the device (not the manufacturer of the motherboard). Be sure to update ALL controllers on the motherboard!
....NOTE: Recently (Nov 2011) we had BSOD issues with the Marvell 91xx controller and an SSD. You may have to switch controllers also.
- Replace the SSD with a platter based hard drive and see if that stops the BSOD's. If it does, then it's likely that there's a problem with the SSD OR an incompatibility with your system.
It's my opinion that SSD's aren't reliable enough (with current hardware) to be used on a system that needs to work reliably. Until I see reliability I will not recommend, nor will I use, SSD's for critical applications.
06 Dec 2011 - This post tends to confirm issues with certain SSD chipsets and certain controllers - [SOLVED] cant find the cause of BSOD F4 - Tech Support Forum
29 May 2012 - The frequency of BSOD's with SSD's seems to have been decreasing over the last several months. It may be approaching time to re-evaluate my stand on their suitability for use in production systems.
AmdTools64.sys Mon Apr 28 13:03:39 2008 (4816036B)
Related to AmdTools64.sys Special Tools Driver from Special Tools Driver
Please un-install this as (I believe) it's no longer supported by AMD
exfat.SYS Mon Jul 13 19:23:29 2009 (4A5BC1F1)
exFAT file system driver
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Thu Oct 18 23:12:01.966 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101812-15147-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 1:59:31.152[/B]
BugCheck Code: [B]BugCheck 4E, {7, 19b29b, 800, 0}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+3727b )[/B]
BugCheck Info: [B]PFN_LIST_CORRUPT (4e)[/B]
BUGCHECK_STR:  0x4E_7
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_0x4E_7_nt!_??_::FNODOBFM::_string_+3727b[/B]
CPUID:        "Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz"
MaxSpeed:     3400
CurrentSpeed: [B]3411[/B]
  BIOS Version                  3305
  BIOS Release Date             04/18/2012
**************************Wed Oct 17 13:23:06.214 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101712-42167-01.dmp]
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]2 days 12:51:47.026[/B]
BugCheck Code: [B]BugCheck 1A, {41284, fdfff9801fd50001, 1bb4b, fffff780c0000000}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+4ac3 )[/B]
BugCheck Info: [B]MEMORY_MANAGEMENT (1a)[/B]
BUGCHECK_STR:  0x1a_41284
PROCESS_NAME: [B]uTorrent.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1a_41284_nt!_??_::FNODOBFM::_string_+4ac3[/B]
MaxSpeed:     3400
  BIOS Version                  3305
**************************Mon Oct 15 00:30:10.737 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101512-40497-01.dmp]
System Uptime:[B]0 days 13:07:53.549[/B]
BugCheck Code: [B]BugCheck 4E, {7, 36ae78, 1, 0}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+3780b )[/B]
PROCESS_NAME: [B]rundll32.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x4E_7_nt!_??_::FNODOBFM::_string_+3780b[/B]
MaxSpeed:     3400
  BIOS Version                  3305
**************************Sun Oct 14 11:21:05.198 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101412-38750-01.dmp]
System Uptime:[B]0 days 9:35:39.010[/B]
BugCheck Code: [B]BugCheck 3B, {c0000005, fffff80002f195d1, fffff88009cbbb80, 0}[/B]
Probably caused by :[B]memory_corruption ( nt!MiGetNextNode+25 )[/B]
BugCheck Info: [B]SYSTEM_SERVICE_EXCEPTION (3b)[/B]
BUGCHECK_STR:  0x3B
PROCESS_NAME: [B]conhost.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!MiGetNextNode+25[/B]
MaxSpeed:     3400
  BIOS Version                  3305
**************************Sun Oct 14 01:44:44.188 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101412-37424-01.dmp]
System Uptime:[B]0 days 11:18:03.000[/B]
BugCheck Code: [B]BugCheck 1A, {41284, fdfff98050440001, e4c2, fffff780c0000000}[/B]
*** WARNING: Unable to verify checksum for win32k.sys
MaxSpeed:     3400
  BIOS Version                  3305
**************************Sat Oct 13 14:26:01.774 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101312-38501-01.dmp]
System Uptime:[B]0 days 9:59:35.961[/B]
BugCheck Code: [B]BugCheck 4E, {99, 28694, 2, 48419}[/B]
Probably caused by :[B]memory_corruption ( nt!MiBadShareCount+4c )[/B]
BUGCHECK_STR:  0x4E_99
PROCESS_NAME: [B]LolClient.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x4E_99_nt!MiBadShareCount+4c[/B]
MaxSpeed:     3400
  BIOS Version                  3305
**************************Sat Oct 13 04:25:19.675 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101312-39593-01.dmp]
System Uptime:[B]0 days 21:04:36.487[/B]
BugCheck Code: [B]BugCheck A, {fffffa801ffc6010, 2, 1, fffff80002f3b366}[/B]
Probably caused by :[B]memory_corruption ( nt!MiReleaseConfirmedPageFileSpace+86 )[/B]
BugCheck Info: [B]IRQL_NOT_LESS_OR_EQUAL (a)[/B]
BUGCHECK_STR:  0xA
PROCESS_NAME: [B]FahCore_16.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0xA_nt!MiReleaseConfirmedPageFileSpace+86[/B]
MaxSpeed:     3400
  BIOS Version                  3305
**************************Fri Oct 12 07:19:35.154 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101212-39452-01.dmp]
System Uptime:[B]2 days 17:23:04.966[/B]
BugCheck Code: [B]BugCheck 3B, {c0000005, fffff80002e65479, fffff8800a0ca9a0, 0}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!RtlEnumerateEntryHashTable+83 )[/B]
BUGCHECK_STR:  0x3B
PROCESS_NAME: [B]LMS.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!RtlEnumerateEntryHashTable+83[/B]
MaxSpeed:     3400
  BIOS Version                  3305
**************************Tue Oct  9 13:55:20.105 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\100912-40638-01.dmp]
System Uptime:[B]4 days 12:37:31.291[/B]
BugCheck Code: [B]BugCheck D1, {d8, 2, 0, fffff880030a1875}[/B]
Probably caused by :[B]memory_corruption[/B]
BugCheck Info: [B]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/B]
DEFAULT_BUCKET_ID:  CODE_CORRUPTION
BUGCHECK_STR:  0xD1
FAILURE_BUCKET_ID: [B]X64_MEMORY_CORRUPTION_ONE_BIT[/B]
MaxSpeed:     3400
  BIOS Version                  3305
**************************Fri Oct  5 01:17:05.102 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\100512-38469-01.dmp]
System Uptime:[B]9 days 1:31:56.000[/B]
BugCheck Code: [B]BugCheck 1A, {41284, fdfff980751fc001, 3440b, fffff780c0000000}[/B]
MaxSpeed:     3400
  BIOS Version                  3305
**************************Tue Sep 25 23:44:26.508 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092512-38001-01.dmp]
System Uptime:[B]0 days 21:31:02.320[/B]
BugCheck Code: [B]BugCheck 3B, {c0000005, fffff8000300ddd3, fffff8800958f750, 0}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!ExFreePoolWithTag+43 )[/B]
BUGCHECK_STR:  0x3B
PROCESS_NAME: [B]Borderlands2.e[/B]
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!ExFreePoolWithTag+43[/B]
MaxSpeed:     3400
  BIOS Version                  3305
**************************Tue Sep 25 02:12:12.648 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092512-37206-01.dmp]
System Uptime:[B]1 days 8:43:57.834[/B]
BugCheck Code: [B]BugCheck 1000007E, {ffffffffc0000005, fffff88004e28435, fffff880040d6778, fffff880040d5fd0}[/B]
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VIDMM_DEVICE::RemoveCommitment+45 )[/B]
BugCheck Info: [B]SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)[/B]
BUGCHECK_STR:  0x7E
FAILURE_BUCKET_ID: [B]X64_0x7E_dxgmms1!VIDMM_DEVICE::RemoveCommitment+45[/B]
MaxSpeed:     3400
  BIOS Version                  3305
**************************Sun Sep 23 17:27:10.190 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092312-32588-01.dmp]
System Uptime:[B]0 days 0:47:45.002[/B]
BugCheck Code: [B]BugCheck 1A, {41284, fdfff9801f4f2001, 58de, fffff780c0000000}[/B]
MaxSpeed:     3400
  BIOS Version                  3305
**************************Sun Sep 23 16:38:41.320 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092312-42198-01.dmp]
System Uptime:[B]1 days 16:40:47.205[/B]
BugCheck Code: [B]BugCheck 4E, {99, 24108, 2, 1f687}[/B]
MaxSpeed:     3400
  BIOS Version                  3305
[/font]
3rd Party Drivers:
[B]AmdTools64.sys              Mon Apr 28 13:03:39 2008 (4816036B)[/B]
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
[B]exfat.SYS                   Mon Jul 13 19:23:29 2009 (4A5BC1F1)[/B]
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
AsUpIO.sys                  Mon Aug  2 22:47:59 2010 (4C57835F)
jraid.sys                   Tue Aug 10 05:28:44 2010 (4C611BCC)
ICCWDT.sys                  Wed Aug 18 04:27:45 2010 (4C6B9981)
AsIO.sys                    Mon Aug 23 21:53:02 2010 (4C7325FE)
HECIx64.sys                 Tue Oct 19 19:33:43 2010 (4CBE2AD7)
AiChargerPlus.sys           Mon Nov  8 01:48:26 2010 (4CD79D3A)
RTKVHD64.sys                Tue May  3 04:27:51 2011 (4DBFBC87)
ALSysIO64.sys               Sat Jul  9 20:27:45 2011 (4E18F201)
e1c62x64.sys                Wed Jul 20 12:37:53 2011 (4E270461)
iaStor.sys                  Wed Aug 24 00:30:39 2011 (4E547E6F)
asmtxhci.sys                Wed Sep 14 03:36:09 2011 (4E705969)
asmthub3.sys                Wed Sep 14 03:36:19 2011 (4E705973)
ASUSFILTER.sys              Tue Sep 20 11:46:33 2011 (4E78B559)
igdkmd64.sys                Mon Mar 19 19:31:54 2012 (4F67C1EA)
AtihdW76.sys                Fri May 11 04:25:40 2012 (4FACCD04)
atikmpag.sys                Fri Jul 27 21:14:47 2012 (50133D07)
atikmdag.sys                Fri Jul 27 21:48:09 2012 (501344D9)
SCDEmu.SYS                  Fri Aug 17 00:19:38 2012 (502DC65A)
SCDEmu.SYS                  Thu Jul 19 04:41:58 2012 (5007C856)
[/font]
Link Removed - Invalid URL
