Hello,
I've had various BSOD's taking place. I upgraded from W7x64 and it seems the most recent BSOD's are the Unexpected Stop Exception error. I can't recall the other one I previously got.
Initially I had a yellow exclamation in device manager, so i removed that, but then got another BSOD. Then I ran sfc and that fixed a couple things, but then it happened again. Installed all the latest updates and video drivers and then it crashed again. So I enabled the minidumps and it happened again, but no dump file. The settings are correct but no file. Actually, I just created the folder manually in case there was an issue writing the file since the folder didn't exist, but it hasn't crashed yet since.
Each time it's crashed it's been when i haven't been using the system so I can't say it was a certain program using it.
I've attached the zip of all the logs from the tool, minus the dumps, since they didn't get recorded. Is this even useful without the dumps? So far, when the settings have been enabled it hasn't written any dump files to the designated location.
