various programs result in APPCRASH!
I'm not sure when it started but some programs result in APPCRASH.
See printscreen:
Anyone suggestions what to do?
Or someone with the same problem?
Grtz,
Dennis
My Specs:
Processor: Core2 E6850 @3000Ghz
Memory: 4Gb
MBoard:ABIT IN9 32X MAX (680i-MCP55PXE)
Videocard: 2x NVIDIA Geforce 8800GTX (SLI)
OS: Windows 7 Home Premium (6.1.7600)
reghakr
Hello Dennis,
Did this occur immediately after install or do you remember making any major changes to your system
Go to Start > Run,and type eventvwr, expand he windows logs section and look for red or yellow flags under this section.Post back with the EventID that is occurring the most.
If you are dual-bootting, is all OK there as i see EasyBCD is crashing.
Are there problems with your dual-boot?
He Reghakr,
I checked eventvwr, the EventID = 1000
As far is I can tell the application errors did occur immediately after the installation, I'm not a 100% sure though.
Dual-booting isn't the problem. I wanted to use EasyBCD to change some Boot options but managed to do that 'the hard way' using command prompt.
Other programs where the Application Error occured are: Keepass and Vistabootpro.
reghakr
Do you have the source of the EventID?
I can"t see a small program like Keepass causing crashes, but possibly VistabootPro.
What exactly is Vistabootpro, and is it necessary?
Did you install Windows 7 last. Are you using the default Windows 7 bootmanager?
Do you have one hard drive or two?
