Windows 7 Ventrilo installs but won't connect
wantasm
Win 7 build 7000. Using Ventrilo build for windows 7 64 bit. Same system booting off XP drive shows vent server up and can connect. Boot to win 7 and can ping server but can't connect. I have tried the session reg fix ( session was not listed anyway). firewall shows Vetrilo as set up with x's in boxes for home network.
Anyone get this to work? some details would help :eek:
hmm did not try XPSP2 compat mode (yet)
PC is at home 3 hours away with no RDP atm., When I ran the troubleshooting on the program Windows 7 7000 64 bit did not suggest xp compat mode, only differeing Vistas whichh did not work. When I bowse to this file exe will I find a XPSP2 on the comp.mode tab? making me think maybe I should uninstall and install XP 32 bit Ventrillo version and try XPSP2 compatibility mode if it is there. :rolleyes:
Hrm, You fumbled the port #? I seemt o be able to conenct but it says my username/pass is incorrect. I've tried using windows Vista Compat, same issue.
I've double and triple checked all the settings as correctly entered.
Running 7100 x64 and x64 3.0.5 Ventrilo Client
Top Bottom
