- Joined
- Aug 27, 2008
I successfully created a 100GB hard drive and then successfully detached it. I was under the assumption that this process would create a virtual hard drive from some where other than my C drive. Hence virtual, and not take physical space from a real drive. I was totally disappointed and for me this process is no better than portioning an existing hard drive and assign it a drive letter. You end up with the same result or am I missing something here. I would be better off just adding another hard drive to my system. Is there a process out there that will create a virtual drive and not take the space from any of your hard drives that are attached to ones system.
