- Thread Author
- #1
I have a question about Virtual PC running in XP mode. I have an old HP Scanjet 4300c (from Windows 98) that I was able to use when I had XP. When I upgraded to VISTA 32 bit in no longer worked because HP did not upgrade drivers for it. Now the questions is this. When I upgrade to Windows 7 64 bit can I download and install the Virtual PC and XP mode software an be able to use the scanner again.
My thinking is, that it should work if it worked in XP. I would just have to download the scanner patch.
