U
Unregistered
Guest
(Im using Vista basic home 32bit)
Ok Im kind of freaking out. You know how you go to your control panel and you can get to a place where you change the color/hue of your taskbar and the top bar of all your windows? I cant find it anymore! It's nowhere in the control panel that I can see and the top part of my windows are just normal solid colors, not that strange wave design as before! How can I correct this? I hate reinstalling vista, is there another option?
