Hello LillyMarz,
I'm sorry to hear you're having trouble with the volume control on your taskbar. Let's troubleshoot this issue and also address your question about enabling the "Peek at desktop" feature.
### Increasing Volume and Making it Stay
If you're unable to raise the volume from the taskbar, there could be a few underlying reasons. Here are some steps you can take to try and resolve this:
1.
Check System Volume Settings: 1. Right-click on the sound icon in the taskbar.
2. Select
Open Volume Mixer
3. Ensure that all sliders are set appropriately and not muted.
2.
Update Audio Drivers: 1. Press
Win + X
, then select
Device Manager
2. Expand the
Sound, video and game controllers
section.
3. Right-click your audio device, then select
Update driver
4. Choose
Search automatically for drivers
3.
Check Sound Settings: 1. Go to
Settings
(Press
Win + I
2. Navigate to
System > Sound
3. Under
Output
, ensure the correct playback device is selected and check its properties.
4.
Run the Audio Troubleshooter: 1. In the same
Sound
settings menu, scroll down to
Troubleshoot
, and follow the prompts.
If none of these steps work, it could be helpful to restart your computer or check for any software conflicts that might be interfering with the volume settings.
### Enabling "Peek at Desktop"
The "Peek at desktop" feature can be useful for quickly viewing the desktop without minimizing your windows. Here's how to enable it:
1.
Using Taskbar Properties: 1. Right-click on an empty space in the taskbar.
2. Select
Taskbar settings
3. Look for the option
Use Peek to preview the desktop when you move your mouse to the Show desktop button at the end of the taskbar
4. Toggle this option to
On
2.
Using System Settings: 1. Go to
Settings
(Press
Win + I
2. Navigate to
Personalization > Taskbar
3. Scroll down to the
option and turn it on.
### Summary Table
Below is a table summarizing the steps:
| Issue | Steps |
Volume Control | 1. Check Volume Mixer <br> 2. Update Audio Drivers <br> 3. Check Sound Settings <br> 4. Run Audio Troubleshooter |
Peek at Desktop | 1. Right-click Taskbar > Taskbar Settings > Toggle Peek option <br> 2. Settings > Personalization > Taskbar > Toggle Peek option |
I hope this helps! If you have any further questions or need more detailed steps, feel free to ask. We're here to help!
Best regards,
