Windows 7 VOLUME HELP!!!
casi
hello. i have a little problem since i have been using ccleaner my audio volume has been going up and down not much but enough i have also been recieving error messages .what shall i do please help because i am a computer imbicil or to put it in another way i am very green:confused:kind regards casi.
If you saved the stuff from registry cleaning portion you should be able to restore it If you can remember when the problem started. System Restore might also fix it. Also what is the error message?
Joe
Hi
You could also update the drivers for your audio card.
That usually gets things back to the default settings.
Let us know what your audio card is and maybe we can tell you where to download the drivers.
Mike
Top Bottom
