Windows 7 VPN Error 691 W 7 64bit
Pontifex
I can't connect to the remote VPN. I did it successfully 1 week ago, when using XP.
Verifying username and password stays too long and after that this error occurs.
I've tried many things, but none of them worked. It is 100% sure that I enter the correct username, password and domain name. Liek I said works properly in XP...
Please help. Seems a lot of people have this problem.
Here is my dxdiag:
System Information
Time of this report: 5/9/2010, 14:24:55
       Machine name: ****
   Operating System: Windows 7 Enterprise 64-bit (6.1, Build 7600) (7600.win7_gdr.100226-1909)
           Language: Bulgarian (Regional Setting: Bulgarian)
System Manufacturer: System manufacturer
       System Model: System Product Name
               BIOS: BIOS Date: 04/30/09 14:56:48 Ver: 08.00.14
          Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 6000+ (2 CPUs), ~3.0GHz
             Memory: 2048MB RAM
Available OS Memory: 2048MB RAM
          Page File: 1395MB used, 2699MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: 120 DPI (125 percent)
 System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.01.7600.16385 64bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
        Sound Tab 2: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: NVIDIA GeForce 8600 GT
       Manufacturer: NVIDIA
          Chip type: GeForce 8600 GT
           DAC type: Integrated RAMDAC
         Device Key: Enum\PCI\VEN_10DE&DEV_0402&SUBSYS_82431043&REV_A1
     Display Memory: 1267 MB
   Dedicated Memory: 499 MB
      Shared Memory: 767 MB
       Current Mode: 1680 x 1050 (32 bit) (59Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: VW202
         Monitor Id: ACI20A2
        Native Mode: 1680 x 1050(p) (59.954Hz)
        Output Type: HD15
        Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
What are your network settings? What VPN connection manager are you using?
Jessica
Microsoft Windows Client Team
Jessica
I am using the built-it windows client. My settings - static IPv4 address, LAN network. No limitations from ISP, no firewall interfering.
I have the same problem as well. Is anybody there able to help on this, i really need my VPN connection to work at least the same like in Vista.
