- Thread Author
- #1
Hello,
I downloaded the student edition of windows 7 Home Premium, I am currently running Vista Ultimate so cannot do an update
and have to do a custom install.
I downloaded it fine, ran it, it opens up fine with the blue windows 7 opening screen, I select install, then select custom install. In the next window I have an empty white box which I presume is supposed to list my HD's allowing me to select where I want to install Windows 7. None of my HD's are showing up, I'm given the option to browse or scan, when I select this it gives me the message-
No device were found. Make sure that the installation media contains the correct drivers, and then click OK
Any suggestions?
Thanks
Any suggestions?
Thanks
- Joined
- Oct 16, 2009
- Messages
- 15,156
- Thread Author
- #3
Not sure if Im running a RAID, how do I find this out? Looking in the BIOS I dont believe I am (if there is where you find out), the drives have been used before and are in use stil.
Slight development too I plugged in a second SATA hard drive that I use for storing music and films on and it recognises this at the install screen, but when I select this HD to install it on( I dont actually want it installed here but just thought Id try anyways) it gave me the error message "setup was unable to create a new system partition"
Also, not sure if this is related, but when I go onto computer management, under disk management, where my HD's should be listed, I only have the second HD I plugged in listed. However under device manager they both appear? Could this be related to my HD not showin up on the install screen on Windows 7?
Regards
Regards
- Joined
- Oct 16, 2009
- Messages
- 15,156
- Thread Author
- #5
I'm having the same issue, though I'd prefer to do an upgrade install rather than a custom install. The upgrade install tells me I don't have enough space although I have approximately 50gb free. I'm assuming it's just not finding my hard drive to upgrade.
I read that the drives dissappearing from disk management could be a problem with a rootkit virus. I got anti-rootkit software to try to fix the problem. It didn't work for me but I'd give it a whirl if I were you, seems like other people have had luck.
Here's where I read about it: Link Removed
Similar threads
- Solved
Windows XP
Nightmare making XP custom install disc
- Replies
- 3
- Views
- 4K
- Replies
- 5
- Views
- 1K
- Replies
- 1
- Views
- 8K
- Replies
- 1
- Views
- 2K
- Replies
- 1
- Views
- 8K
