I have a Gateway desktop. Two days ago I found I can't load two web pages: www.hotmail.com and www.facebook.com The url shows the right address but the data is missing.
0. Restore the computer to 3 days or more ago and try again. (Also, check your MTU value if it is what it should be - required by your ISP). 1. Do you use a router? Try resting it. (Usually there will be a reset button witch you should press and hold for about 50 seconds). 2. Try disabling Firwalls and try again. 3. Check if your HOSTS file only has one line: 127.0.0.1 localhost 4. what do you mean "no data"? Are there red X's where data should be? Can you upload a screen image?
