weird bsod!!
Today i have bought a new laptop N55sf 1060V , and everything is perfect , runs smoothly and it's really fast! the only problem is that when i tried to send it to hibernation / suspension it gets stuck : the screen turns black as it should be but the fan keeps running and it doesn't shut down properly , lights are still on and you can hear it running.
after like 10 minutes of blackness , a bsod pops out saying power state failure and the sistem shuts down and the laptop restarts and veerything works again .
I have no idea what the problem could be , as it's brand new and i haven't installed anything on it yet ( i've only downlaoded a benchmark and installed an antivirus suggested by asus itself)
since it's new it's still covered by warranty but i don't feel like sending it back , also because i bought it online!
any idea of what the problem is?
Thank you in advance
Elmer
Hi nemar.
What was the AV suggested by Asus? Can you help us out with a few things:
We really need to see the DMP file as it contains the only record of the sequence of events leading up to the crash, what drivers were loaded, and what was responsible.
To ensure minidumps are enabled:
Go to Start, in the Search Box type: sysdm.cpl, press Enter.
Under the Advanced tab, click on the Startup and Recovery Settings... button.
Ensure that Automatically restart is unchecked.
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box (the 256kb varies).
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump.
OK your way out.
Reboot if changes have been made.
The .dmp files are located at C:\Windows\Minidump. Until a .dmp file is generated, the Minidump folder may not exist.
Go to your C:\Windows\Minidump folder. Copy the .dmp files to a new folder on your desktop. Zip up that folder and attach to a post.
Please see: How to ask for help with a BSOD problem Following Method 2:
Download
and run the SF Diagnostics Tool. Right click the SF Diag tool and select Run as Administrator before running. When the reports have been created, zip them up and attach to a post.
Download and run CPU-Z. Take screenshots**/snips of the CPU tab, Mainboard tab, Memory tab and all the slot #'s under the SPD tab.
Go to Post Reply, click on the Go Advanced button and attach the screenshots**/snips to your post for all the RAM experts to see by using the paper clip you will find on the top toolbar. Do not zip them up.
If screenshots, please crop.
Also see: http://windows7forums.com/blue-scre...lp-us-help-you-filling-your-system-specs.html
When attaching dmp files, PLEASE put them in a single zipped folder
Hi nemar.
OK your way out.
Download
hi , sorry for the late reply.
anyway the antivirus is trend micro.
here are the screenshots u required
1.jpg 2.jpg 3.jpg View attachment Nuova cartella.zip View attachment Seven Forums.zip
and attached here are the files u asked me to zip.
i hope i've done everything correctly!!!
thanks,
nemar
Elmer
STOP 0x0000009F: DRIVER_POWER_STATE_FAILURE
Usual causes:
Device driver
Your latest dump file lists NETwNs64.sys as the probable cause.
This is an Intel Wireless WiFi 5000 Series Driver.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes.
Random stop codes can often indicate hardware issues.
As a Priority:
While blue screening re-set your cpu to 2.2ghz from the overclock of 2.8ghz you are currently running.
dtsoftbus01.sys Mon Oct 17 13:12:30 2011 The dtsoftbus01.sys driver has been known to cause problems on some Windows 7 systems. This belongs to Daemon Tools Light. I suggest uninstalling DT Light until your blue screens are resolved. But do not replace with Daemon Tools!!
NETwNs64.sys Sun Sep 18 10:26:48 2011 Use the Intel® Driver Update Utility (in Internet Explorer gives me the best results). See what updates are available.
For now, Remove Trend Micro (help here: Security Software | SingularLabs) and replace with bsod friendly Microsoft Security Essentials
Drivers that pre-date Windows 7. Update:
GEARAspiWDM.sys Mon May 18 13:17:04 2009 Gear Software CD-ROM Class Filter Driver v4.019.1 (Oct 2011). Also loads with iTunes
Bugcheck Analysis:
BugCheck 9F, {3, fffffa8007b42060, fffff80000b9c3d8, fffffa800d69ac10}
*** WARNING: Unable to verify timestamp for NETwNs64.sys
*** ERROR: Module load completed but symbols could not be loaded for NETwNs64.sys
Probably caused by : NETwNs64.sys
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa8007b42060, Physical Device Object of the stack
Arg3: fffff80000b9c3d8, Functional Device Object of the stack
Arg4: fffffa800d69ac10, The blocked IRP
Drivers:
fffff880`00ec4000 fffff880`00f1b000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`01400000 fffff880`01489000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`07c5a000 fffff880`07c70000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`08ff6000 fffff880`08ff8700   AiCharger AiCharger.sys Fri Feb 25 09:41:45 2011 (4D677959)
fffff880`013ea000 fffff880`013f5000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`09200000 fffff880`09250000   AMPPAL   AMPPAL.sys   Thu Sep 15 17:48:22 2011 (4E722C56)
fffff880`06771000 fffff880`06779000   ASMMAP64 ASMMAP64.sys Thu Jul 02 10:13:26 2009 (4A4C7A36)
fffff880`0ae28000 fffff880`0ae4c000   asmthub3 asmthub3.sys Mon Oct 03 11:20:27 2011 (4E898C6B)
fffff880`09b2b000 fffff880`09b8f000   asmtxhci asmtxhci.sys Mon Oct 03 11:20:17 2011 (4E898C61)
fffff880`013ac000 fffff880`013b5000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`013b5000 fffff880`013df000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`0798d000 fffff880`07996000   atkwmiacpi64 atkwmiacpi64.sys Wed Sep 07 02:44:52 2011 (4E66CC94)
fffff960`00880000 fffff960`008e1000   ATMFD    ATMFD.DLL    Sat Feb 19 09:00:32 2011 (4D5F86B0)
fffff880`00f8c000 fffff880`00f98000   BATTC    BATTC.SYS    Tue Jul 14 00:31:01 2009 (4A5BC3B5)
fffff880`049f2000 fffff880`049f9000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`0797c000 fffff880`0798d000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`066c9000 fffff880`066e7000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`00640000 fffff960`00667000   cdd      cdd.dll      Sat Nov 20 12:55:34 2010 (4CE7C546)
fffff880`0ddcc000 fffff880`0ddf6000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00d2d000 fffff880`00ded000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01d69000 fffff880`01d99000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00ccf000 fffff880`00d2d000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`07c26000 fffff880`07c2a500   CmBatt   CmBatt.sys   Tue Jul 14 00:31:03 2009 (4A5BC3B7)
fffff880`0155a000 fffff880`015cc000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`00f83000 fffff880`00f8c000   compbatt compbatt.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`07c4a000 fffff880`07c5a000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`0ddab000 fffff880`0ddb9000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`078db000 fffff880`0795e000   csc      csc.sys      Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`0795e000 fffff880`0797c000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`04590000 fffff880`0459f000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01d53000 fffff880`01d69000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0ae00000 fffff880`0ae22000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`01da7000 fffff880`01def000   dtsoftbus01 dtsoftbus01.sys Mon Oct 17 13:12:30 2011 (4E9C1BAE)
fffff880`0ddb9000 fffff880`0ddcc000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`0460e000 fffff880`049a8000   dump_iaStor dump_iaStor.sys Tue Apr 26 19:06:18 2011 (4DB7099A)
fffff880`0ae4c000 fffff880`0ae58000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`0443f000 fffff880`04533000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`04533000 fffff880`04579000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`0dd56000 fffff880`0dd8c000   fastfat  fastfat.SYS  Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`014e8000 fffff880`014fc000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`0149c000 fffff880`014e8000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`01611000 fffff880`0161b000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01d19000 fffff880`01d53000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01c0c000 fffff880`01c56000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`0dc00000 fffff880`0dc0d000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff880`0dd8c000 fffff880`0dd98000   GPU_Z    GPU-Z.sys    Wed Oct 06 17:14:37 2010 (4CACA06D)
fffff800`035f0000 fffff800`03639000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`100d9000 fffff880`100fd000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`08fe5000 fffff880`08ff6000   HECIx64  HECIx64.sys  Tue Sep 21 17:59:04 2010 (4C98E458)
fffff880`06600000 fffff880`066c9000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01d10000 fffff880`01d19000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`09bab000 fffff880`09bc9000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01012000 fffff880`013ac000   iaStor   iaStor.sys   Tue Apr 26 19:06:18 2011 (4DB7099A)
fffff880`08427000 fffff880`08fe4660   igdkmd64 igdkmd64.sys Fri Oct 21 18:29:55 2011 (4EA1AC13)
fffff880`07c34000 fffff880`07c4a000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`08411000 fffff880`0841d000   iwdbus   iwdbus.sys   Wed Mar 09 23:43:23 2011 (4D78109B)
fffff880`07c17000 fffff880`07c26000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`07c0f000 fffff880`07c17000   kbfiltr  kbfiltr.sys  Mon Jul 20 10:21:42 2009 (4A643726)
fffff800`00baa000 fffff800`00bb4000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`10138000 fffff880`1017b000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`017d8000 fffff880`017f3000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`0199a000 fffff880`019c5000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`0ae22000 fffff880`0ae27200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`09b8f000 fffff880`09bab000   L1C62x64 L1C62x64.sys Mon Sep 19 08:42:11 2011 (4E76F253)
fffff880`07640000 fffff880`07655000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0aeb4000 fffff880`0aed7000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c6c000 fffff880`00cbb000   mcupdate mcupdate.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`0ae79000 fffff880`0ae87000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`07c00000 fffff880`07c0f000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`00fc4000 fffff880`00fde000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`06779000 fffff880`06791000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`06791000 fffff880`067be000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`09e79000 fffff880`09ec7000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`09ec7000 fffff880`09eeb000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`013df000 fffff880`013ea000   msahci   msahci.sys   Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`01809000 fffff880`01814000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f24000 fffff880`00f2e000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`014fc000 fffff880`0155a000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`04585000 fffff880`04590000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01cfe000 fffff880`01d10000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`01847000 fffff880`0193a000   ndis     ndis.sys     Wed Dec 29 06:16:18 2010 (4D1AD232)
fffff880`07c70000 fffff880`07c7c000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`0673f000 fffff880`06752000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`09bc9000 fffff880`09bf8000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`101e7000 fffff880`101fc000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`07729000 fffff880`07738000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`0769f000 fffff880`076e4000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`0193a000 fffff880`0199a000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`09298000 fffff880`09b1e000   NETwNs64 NETwNs64.sys Sun Sep 18 10:26:48 2011 (4E75B958)
fffff880`01814000 fffff880`01825000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`04579000 fffff880`04585000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`03007000 fffff800`035f0000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`01635000 fffff880`017d8000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`049e9000 fffff880`049f2000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`07600000 fffff880`07640000   nvkflt   nvkflt.sys   Mon Oct 31 12:12:25 2011 (4EAE90A9)
fffff880`0f404000 fffff880`10083000   nvlddmkm nvlddmkm.sys Mon Oct 31 12:11:23 2011 (4EAE906B)
fffff880`01cf4000 fffff880`01cfe000   nvpciflt nvpciflt.sys Mon Oct 31 12:12:06 2011 (4EAE9096)
fffff880`066ec000 fffff880`0673f000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`076ed000 fffff880`07713000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00f6e000 fffff880`00f83000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00f2e000 fffff880`00f61000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00fad000 fffff880`00fb4000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00fb4000 fffff880`00fc4000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01600000 fffff880`01611000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`09f46000 fffff880`09fec000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`0b1ab000 fffff880`0b1e8000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00cbb000 fffff880`00ccf000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`09250000 fffff880`09274000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`09274000 fffff880`0928f000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`100fd000 fffff880`1011e000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`1011e000 fffff880`10138000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`07783000 fffff880`077d4000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`07c7c000 fffff880`07c87000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`019ea000 fffff880`019f3000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`019f3000 fffff880`019fc000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01800000 fffff880`01809000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01cba000 fffff880`01cf4000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`045cd000 fffff880`045f9000   rfcomm   rfcomm.sys   Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`0e83f000 fffff880`0e9f5000   rikvm_38F51D56 rikvm_38F51D56.sys Fri Oct 29 11:52:09 2010 (4CCAA759)
fffff880`06752000 fffff880`0676a000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0aedb000 fffff880`0b1aae80   RTKVHD64 RTKVHD64.sys Tue Nov 22 09:59:22 2011 (4ECB727A)
fffff880`0e800000 fffff880`0e80b000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`01cb2000 fffff880`01cba000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`0dcbe000 fffff880`0dd56000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`09e00000 fffff880`09e69000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`0e80b000 fffff880`0e83c000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`07c87000 fffff880`07c88480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`07c91000 fffff880`07df6000   SynTP    SynTP.sys    Fri May 06 03:28:49 2011 (4DC35CE1)
fffff880`01a08000 fffff880`01c0c000   tcpip    tcpip.sys    Tue Jun 21 04:33:55 2011 (4E001123)
fffff880`09fec000 fffff880`09ffe000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`0161b000 fffff880`01628000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`01825000 fffff880`01847000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`0776f000 fffff880`07783000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff880`09f28000 fffff880`09f46000   tmactmon tmactmon.sys Wed Jul 21 08:31:24 2010 (4C46A24C)
fffff880`09eeb000 fffff880`09f12000   tmcomm   tmcomm.sys   Wed Jul 21 08:31:15 2010 (4C46A243)
fffff880`09f12000 fffff880`09f28000   tmevtmgr tmevtmgr.sys Wed Jul 21 08:31:15 2010 (4C46A243)
fffff880`07753000 fffff880`0776f000   tmtdi    tmtdi.sys    Tue Jul 20 09:58:07 2010 (4C45651F)
fffff960`00520000 fffff960`0052a000   TSDDD    TSDDD.dll    Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`07996000 fffff880`079bc000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`0676a000 fffff880`06771000   TurboB   TurboB.sys   Sat Apr 17 00:07:26 2010 (4BC8EDAE)
fffff880`1017b000 fffff880`1018d000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`079dd000 fffff880`079fa000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`07df6000 fffff880`07df7f00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`08400000 fffff880`08411000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`1018d000 fffff880`101e7000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`10083000 fffff880`100d9000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`0459f000 fffff880`045cc280   usbvideo usbvideo.sys Sat Nov 20 10:44:34 2010 (4CE7A692)
fffff880`00f61000 fffff880`00f6e000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`04600000 fffff880`0460e000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`019c5000 fffff880`019ea000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`01c56000 fffff880`01c66000   vmstorfl vmstorfl.sys Sat Nov 20 09:57:30 2010 (4CE79B8A)
fffff880`00f98000 fffff880`00fad000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01c66000 fffff880`01cb2000   volsnap  volsnap.sys  Fri Feb 25 03:38:18 2011 (4D67242A)
fffff880`09b1e000 fffff880`09b2b000   vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`07713000 fffff880`07729000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`0e9f5000 fffff880`0e9ff000   vwifimp  vwifimp.sys  Tue Jul 14 01:07:28 2009 (4A5BCC40)
fffff880`07738000 fffff880`07753000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`01def000 fffff880`01dff000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e11000 fffff880`00eb5000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00eb5000 fffff880`00ec4000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`076e4000 fffff880`076ed000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`000c0000 fffff960`003d3000   win32k   win32k.sys   Sat Jun 11 04:06:57 2011 (4DF2DBD1)
fffff880`07c2b000 fffff880`07c34000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f1b000 fffff880`00f24000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`079bc000 fffff880`079dd000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`0dc0d000 fffff880`0dc1e000   usbaapl64.sy
    Checksum:  00000000
    ImageSize:  00011000
fffff880`0dc71000 fffff880`0dc8c000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`049bf000 fffff880`049e9000   cdrom.sys
    Checksum:  00000000
    ImageSize:  0002A000
fffff880`0dcad000 fffff880`0dcbb000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0460e000 fffff880`049a8000   dump_iaStor.
    Checksum:  00000000
    ImageSize:  0039A000
fffff880`0dd98000 fffff880`0ddab000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0dc8c000 fffff880`0dc9a000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0039A000
fffff880`0dc9a000 fffff880`0dcad000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0ae58000 fffff880`0ae66000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0039A000
fffff880`0ae66000 fffff880`0ae79000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0dc00000 fffff880`0dc71000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  00071000
fffff880`0b1e8000 fffff880`0b1f8000   BthEnum.sys
    Checksum:  00000000
    ImageSize:  00010000
fffff880`0784c000 fffff880`078d8000   bthport.sys
    Checksum:  00000000
    ImageSize:  0008C000
fffff880`0ae9c000 fffff880`0aeb4000   BTHUSB.sys
    Checksum:  00000000
    ImageSize:  00018000
fffff880`07800000 fffff880`0784c000   btmhsf.sys
    Checksum:  00000000
    ImageSize:  0004C000
fffff880`0ae87000 fffff880`0ae9c000   iBtFltCoex.s
    Checksum:  00000000
    ImageSize:  00015000
fffff880`04400000 fffff880`04420000   bthpan.sys
    Checksum:  00000000
    ImageSize:  00020000
fffff880`04420000 fffff880`04434000   btmaux.sys
    Checksum:  00000000
    ImageSize:  00014000
fffff880`01d99000 fffff880`01da7000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`04612000 fffff880`049ac000   dump_iaStor.
    Checksum:  00000000
    ImageSize:  0039A000
fffff880`049ac000 fffff880`049bf000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
Usual causes:
Device driver
As a Priority:
Bugcheck Analysis:
0: kd> !analyze -v
Arguments:
Drivers:
Unloaded modules:
    Checksum:  00000000
    ImageSize:  00011000
    Checksum:  00000000
    ImageSize:  0001B000
    Checksum:  00000000
    ImageSize:  0002A000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0039A000
    Checksum:  00000000
    ImageSize:  00013000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0039A000
    Checksum:  00000000
    ImageSize:  00013000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0039A000
    Checksum:  00000000
    ImageSize:  00013000
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  00010000
    Checksum:  00000000
    ImageSize:  0008C000
    Checksum:  00000000
    ImageSize:  00018000
    Checksum:  00000000
    ImageSize:  0004C000
    Checksum:  00000000
    ImageSize:  00015000
    Checksum:  00000000
    ImageSize:  00020000
    Checksum:  00000000
    ImageSize:  00014000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0039A000
    Checksum:  00000000
    ImageSize:  00013000
HTH.
I have resolved the suspension/hibernation problem , downloading the wireless thing you told me to, but i think i've messed up my internet connection now :(
it's working fine but everytime i turn on the pc from a reboot or from a suspension , i have to go through the repair process bevcause it says that ther's a problem with the lan conenction. Using the repair device of windows i can resolve it and it works again , it says the problem is that the connection is turned off , and it turns it on again , but then it says the the wireless board is not working properly an it cant resolve that problem.
So everytime i reboot i have to go through the process again :(
Trouble
Noob Whisperer
but i think i've messed up my internet connection now it's working fine but everytime i turn on the pc from a reboot or from a suspension , i have to go through the repair process bevcause it says that ther's a problem with the lan conenction. Using the repair device of windows i can resolve it and it works again , it says the problem is that the connection is turned off , and it turns it on again , but then it says the the wireless board is not working properly an it cant resolve that problem.
Likely a result of having updated the driver. You will likely have to experiment a bit and see what power settings and features that may have either been changed or removed as a result of the new driver.
Additional notes:
Features removed from this version:
Wake on wireless LAN is not present in this version of the application.
SOURCE: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20791&ProdId=3141&lang=eng&OSVersion=Windows 7 (64-bit)*&DownloadType=Software Applications
Check your power scheme in the control panel, specifically as it pertains to "Wireless Adapter Settings" and
Check the device properties in Device Manager->Power Management Tab and consider unchecking the "Allow the computer to turn off this device to save power" check box. And
while you are there check the "Advanced" tab just to see if there are any additional controls respect to the radio (on/off) default condition or additional power saving options. See attachment
#7
I've done as you told me , but the problem is still there :( It's nothing serious , it takes me a few minutes to solvee it but still it's very annoying since i have to do it everytime i turn it on! also sometimes it just disconnects itself from the web conenction and in about 2 minutes it manages to connect again , for no reason..
Trouble
Noob Whisperer
#8
I don't know how much irritation I would put up with from a brand new purchase. You shouldn't be having any of these problems. And you definitely shouldn't have to accept anything short of proper operation and performance.
My suggestion would be to take it back or send it back, or at the very least contact the vendor and start a trouble ticket. There is no reason that I can see for you to be jumping through hoops to get a brand new machine to act properly.
Regards
Randy
