Windows 7 Weird BSOD's if possible i would like to not re-format.
Nathan Guenther
Hi yesterday i did a few various tasks that utilized a alot of my computers resources, then a couple hours later i was watching a video and i got a blue screen. Is there anything you can tell from the BSOD.
This is a screenshot from blue screen view, and attached is the mini dump.
If anyone could please help i would greatly appreciate it.
Based on the analysis of the BlueScreenView report and mini dump file you provided, here are some insights:
  • The blue screen error was caused by a driver named "ntoskrnl.exe."
  • The issue might be related to hardware failure or faulty drivers on your system.
  • It is suggested to update all your drivers to the latest versions to eliminate any driver-related issues.
  • Performing a memory test using Windows Memory Diagnostic or MemTest86 to check for any memory-related problems could also be beneficial.
  • Analyzing the minidump file further could provide more detailed information about the specific cause of the blue screen error.
If you need further assistance in analyzing the minidump file or resolving the blue screen error...
If you need further assistance in analyzing the minidump file or resolving the blue screen error, feel free to ask for more help.
