Windows 7 What TV-PCI card
vintageneo
I am looking at buying a new PCI card to use for TV. Anyone have ones they know work? I had an adaptec and it worked on the 7 beta but it won't work on the RC. Maybe you might have suggestions on how to get that to work also. Anyway, please respond with comments, suggestions, or advice. Thanks!
glenmorangie
Hauppauge HVR 2200
Just installed the above card in RC 7100. Using WinTV7, after a bit of trying, I got it to work. Install the card and see if the driver installs, if not, let Windows search and the driver should go in. Working well on both Analog & Digital TV in Australia. (By the way, this is a PCI-E card)
