P
PhantomBurn
Guest
Hey,
I was just wondering if anyone knew of a sound card that has What U Hear enabled on it, and works with a laptop (PCI Express Only).
I looked at all the Sound Blaster ones, but only 2 are for a laptop, and the only PCI Express is the PCI Express X-Fi Xtreme Audio and I read this on their site:
"The What U Hear recording option is supported in Windows Vista for Sound Blaster X-Fi series (excluding Extreme Audio series) and Sound Blaster Audigy series (excluding Sound Blaster Audigy LE, SE, and Audigy Value)."
So the Extreme Audio doesn't support it supposedly.
So does anyone know of one that will work?
Thanks for any help in advance!
