I'm new to Windows 7 and networking but have an ASUS wireless laptop connected to my home PC by a Netgear ADSL modem/wireless router (DG834GVv2). Both systems are running Windows 7 - 32 bit and can both access the internet. They are both in the same Home Group and have everything ticked under the "Share libraries and printers" options.
I also have a 3rd PC hooked up to the network which is running Windows XP so I've given all 3 machines the same Workgroup name (which is a different name to the Home Group name). It would be good to have the Windows XP computer networked as well but that isn't a priority, I mainly want the wireless laptop to file share with the Windows 7 PC.
The laptop can see the PC on the network and the PC can see the laptop but when I try to access either of them I get the "Windows cannot access \\" error message and something about check the spelling of the name. When I run the network trouble-shooter it says "Your broadband modem is experiencing connectivity issues" and the Problems Found are "The connection between your access point, router, or cable modem and the internet is broken".
I don't really understand this error because as I said they can both access the internet ok and see each other on the network.
Anyone got any ideas what the problem might be because I rang Netgear for help and they wanted to charge me $159 to sign up for one years support.
