Hi, I am hoping someone will be kind enough to point me in the right direction with a nightmare of an install I am going through. Here are the details:
Fresh install of Win 7 Pro 64 goes smoothly. I go ahead and update my motherboard and video drivers (LAN, USB 3.0, etc) with latest versions. I then go and run Windows Updates, again with no issues. I begin to install software. The computer is restarted as needed and all seems ok. At some point, I shut down for the night. Next time the computer starts I get the "Windows is loading files..." or something to that extent with a progress bar and then it tells me that I can either repair windows or start windows normally. Restarting windows gets me back to the same place and repairing doesn't work at all.
I have tried installing the mobo drivers, then software, one by one with a restore point after each, then Win7 updates. After the updates come in, something becomes disrupted and the computer no longer wants to boot properly. Going back to an earlier restore point does not work either. Again, the odd thing is that the problem occurs AFTER a prolonged shut down of the computer.
Anyone have any suggestions with this? It's literally causing me to pull my hair out in frustration.
Thanks in advance!
Thanks in advance!
