Win 7 shares not accessible to media player device - MS-RAP missing?
I have posted on several forums, followed 100s of 'tips', but nothing works!
Briefly: Technisat media player can share files on Vista, Android Samba, linux-based NAS without user verification but fails to access Win7 shares with a user/password login failure (although the share is available to Everyone, and other devices can share the Win 7).
I have been told that this is because MS-RAP is deprecated and the only workaround is Xp-Mode (run a virtual OS on a virtual disc to share files - unbelievable!).
Does anyone have a solution to this problem? Is there an update file to reinstate Vista-like sharing?
Sadly, there's no possibility to update the network stack on the device.
I'd appreciate any help - bear in mind I have changed all the usual registry tips for compatibility with other systems (all of which still work, yet Win7 doggedly refuses access to this one device).
I think this forum is my last hope.
Trouble
Noob Whisperer
Not sure if all your previous efforts have included this policy setting (actually three policy settings) regarding NTLMv2 but it might be worth a try. See attachment.
Thanks for the reply ... sadly all those settings were already as you suggested!
Here's some trace detail on the problem:
Virtual XP Mode on Windows 7:
1 0.000000 {NbtSS:3, TCP:2, IPv4:1} 192.168.178.22 192.168.178.27 SMB SMB:C; Tree Connect Andx, Path = \\VIRTUALXP-62006\IPC$, Service = ?????
2 0.000000 {NbtSS:3, TCP:2, IPv4:1} 192.168.178.27 192.168.178.22 SMB SMB:R; Tree Connect Andx, Service = IPC
3 0.000000 {SMB:4, NbtSS:3, TCP:2, IPv4:1} 192.168.178.22 192.168.178.27 RAP RAP:NetShareEnum Request, InfoLevel = 1
4 0.000000 {SMB:4, NbtSS:3, TCP:2, IPv4:1} 192.168.178.27 192.168.178.22 RAP RAP:NetShareEnum Response, Count = 4
Fail on Windows 7 with "not supported":
1 0.000000 {NbtSS:3, TCP:2, IPv4:1} 192.168.178.22 192.168.178.23 SMB SMB:C; Tree Connect Andx, Path = \\xxxNB\IPC$, Service = ?????
2 0.000000 {NbtSS:3, TCP:2, IPv4:1} 192.168.178.23 192.168.178.22 SMB SMB:R; Tree Connect Andx, Service = IPC
3 0.000000 {SMB:4, NbtSS:3, TCP:2, IPv4:1} 192.168.178.22 192.168.178.23 RAP RAP:NetShareEnum Request, InfoLevel = 1
4 0.000000 {NbtSS:3, TCP:2, IPv4:1} 192.168.178.23 192.168.178.22 SMB SMB:R; Transact - DOS OS Error, (50) NOT_SUPPORTED
Absolutely crazy ... MS should really issue an optional patch for this problem.
If you have any other ideas ....???!!!
