I am not aware that MS are going to launch any new sounds, but if you google, you will find a few pages with ready made schemes. All you need to do is load them into Windows/Media and they will then be selectable from the Sound - Sounds panel
thanks have you done this..
because i was just wondering if you have ever used the vista pearl scheme ?
anyway i want that scheme.. with a a bit of the vista ultimate scheme..
I have not, I don't pay much attention to the sounds, to tell the trut, but I see no reason why it should be a problem. I have had a looki and it seems OK. No danger to your system.
