Windows 7 win7 pro loads fine but freezes at any programme launch
1945bob
running in safe mode.anytime a try to run win7 pro 64bit any click freezes windows.have run all the troubleshooters, the one that i cant resolve is windows update. it has "probable corrupted files"..it (win update) wont run in safe mode.
any takers?
I am willing to try.
Possibly caused by a bad update - try running a system restore in safe mode to some date which precedes the start of the problem.
Why do you want to run programs in safe mode?
The safe mode doesnt really start with all the drivers that are needed.
there are four possible restore points .I have tried all of them.they do not work. I get an error message.
thanks
b
because win 7 will load in regular mode but if i click on anything, windows freezes...not responding...cant exit.. task mgr wont run...requires a hard re- boot( pull plug)..
thanks
b
win update troubleshooter responds with "update database error ox80070005"
"wupdate components must be repaired"
so OK how would one go about repairing the components. thanks
b
Try running a system file check - run a command prompt as administrator and enter the command:
sfc /scannow
ran malwarebytes twice(as administrator)I am the only user.one quick scan and one full scan. No problems.thanks
B
Maybe some faulty peripheral hardware? Tried to unplug all unused components?
Or do a virus scan with kaspersky rescue cd to check if your infected.
