superpan
Honorable Member
I am using AverMedia M135 TV card ,when i try to watch tv with Windows Media Center i get this gray screen, i can hear the sound but i cant watch tv :confused:
It seems like you're facing an issue with your AverMedia M135 TV card when trying to watch TV through Windows Media Center. This problem could be due to various reasons such as driver issues, compatibility problems, or settings configuration. Here are a few steps you can try to troubleshoot and resolve the gray screen issue: 1. Check Drivers: - Ensure that you have the latest drivers installed for your AverMedia M135 TV card. Sometimes, outdated drivers can cause compatibility issues. 2. Compatibility Check: - Verify if your AverMedia M135 TV card is compatible with Windows Media Center and your operating system. 3. Restart Windows Media Center: - Close Windows Media Center, restart your computer, and then try opening...
It seems like you're facing an issue with your AverMedia M135 TV card when trying to watch TV through Windows Media Center. This problem could be due to various reasons such as driver issues, compatibility problems, or settings configuration. Here are a few steps you can try to troubleshoot and resolve the gray screen issue: 1. Check Drivers: - Ensure that you have the latest drivers installed for your AverMedia M135 TV card. Sometimes, outdated drivers can cause compatibility issues. 2. Compatibility Check: - Verify if your AverMedia M135 TV card is compatible with Windows Media Center and your operating system. 3. Restart Windows Media Center: - Close Windows Media Center, restart your computer, and then try opening it again to see if the issue persists. 4. Check Connections: - Ensure that all cables and connections between your TV card and the computer are secure and properly connected. 5. Update Windows: - Make sure your Windows operating system is up to date with the latest updates and patches. 6. Adjust Settings: - Check the display settings within Windows Media Center to ensure they are configured correctly, especially the video output settings. 7. Test with Different Software: - Try using alternative TV viewing software to see if the issue is specific to Windows Media Center. 8. Contact Support: - If none of the above steps resolve the issue, consider contacting AverMedia support for further assistance. Try these steps and let me know if the issue persists. If you need further assistance, feel free to ask!
