- Thread Author
- #1
I have a WIn7 laptop and an XP desktop connected to a Linksys wireless router (WRTG542); the laptop has two network connections: a wireless connection (when I move it away) and the lan cable. The desktop only has a lan cable connection. But there are problems:
While both computers can see eachother and access shared resources (folders, files, printers connected to the XP), this is the case ONLY when the XP's Windows firewall is turned off.
The Win7 cannot generate a network map for either of the network connections. When I try to create a new network connection, the laptop "thinks" the router is a WRT160N, which I used to have a long time ago (I think). When I try to genreate a map for the wireless connection, I'm told it is public and I don't see where I can change that. BUT for the lan connection, the map correctly identifes the router brand.
