Window 7 Printing Issue
I just received some new windows updates on Friday and now I cannot print. My printers show up in Printers and Devices area, but when I click pring in Excel, Word, IE, it says "Before you can print you need to install a printer..." I have restarted the computer and then none of my printers show in the Printers and Devices area. Is anyone else having this problem? Any help would be much appreciated. Thanks in advance.
ickymay
I would try reinstalling the printer, and print a test page ?
is this a wireless device ?
I cannot uninstall the printer. It is classified as an Unspecified device on the Printers and Devices window. I can't even delete the printer to try and reinstall it. Any other thoughts? Thanks.
Trouble
Noob Whisperer
Have you considered a system restore to a restore point prior to friday. Or if, as you suspect, a windows update, you could try just unistalling the update
ickymay
can you remove it from print server properties ?
then force it to use the latest driver downloaded from the manufacturers website ?
We had this issue come up and for some reason we had to go into services and stop all the Bluetooth services and set them to manual. Once we rebooted it cleared up the issue on our end.
