WIndows 7 32 bit - BSOD with ntoskrnl.exe problem - Help needed!
Good day!
Hi. I have problem on BSOD with ntoskrnl.exe. It has been a big problem for me for the past 2 weeks. I have no idea what is happening. Occasionally it appears pretty frequent, however, sometimes it takes a day to get BSOD again. After numerous of occurrence, I notice that sometimes when I click the windows explorer quick launch, the BSOD just turn up! I hereby attached the zip file of the minidump I have saved. Hope someone can help me with this problem.
Many thanks in advance!
PS: My specs are as the pictures attached.
Welcome.
You hafta post your spd tab too. The memory is either defective or set unwell in the bios. I can tell you which when I see the new jpg.
Welcome.
Hi there. Thanks for replying. Can you tell me what is hafta post and spd tab?
The tab in CPU-Z that you didn't post yet.
Opps. This is the last one that I missed.
Remove Norton AND AVG in safe mode with the tools to see how it goes. Boot to normal mode after that's done and install MSE to replace.
Google is your friend for the tools and MSE too.
Might be good. Post any new crash dumps after if they happen.
Dear TorrentG,
I am sorry that I ask too many questions. Does it mean that my RAM has problem? What is RMA? When you say replace the RAM entirely with a new matching set, does it mean buying new RAM and Motherboard? Actually I have just bought this laptop in Aug 2010
#8
I edited my post. Re-check it and follow what it says....
#9
Thank you so much! I will follow your instruction.
#10
Hi TorrentG,
I have followed all your instructions on using tools to remove AVG and Norton Antivirus and install MSE. However, the problem still persists when I clicked on the windows explorer icon. Attached is the minidump. Hope you can help me.....Thank you so much
#11
This last crash was caused by Intel Matrix Storage driver:
122810-20202-01.dmp
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
interrupt request level (IRQL) that is too high. This is usually
Probably caused by : iaStor.sys ( iaStor+4397f )
iaStor.sys Fri Jan 15 15:04:54 2010
80e1cdac 8947597f badb0d00 00000000 00000000 nt!KiTrap0E+0x2cf
WARNING: Stack unwind information not available. Following frames may be wrong.
80e1ce38 89458f07 b65bd9d0 b65bd9d0 86171020 iaStor+0x4397f
80e1ce50 8943a490 fffffff5 fffffff5 b65bd9d0 iaStor+0x26f07
80e1ce68 8943b0c4 86171020 b65bd9d0 83040458 iaStor+0x8490
80e1ce84 8943b116 01171020 80e1ceb4 86171020 iaStor+0x90c4
80e1ce98 8943b72f 86171020 80e1ceb4 80dfda00 iaStor+0x9116
80e1cf34 89458833 86171020 00000000 8cf46adc iaStor+0x972f
80e1cf48 83065835 86166460 86164000 00000000 iaStor+0x26833
80e1cfa4 83065698 80dfc120 8cf46a58 00000000 nt!KiExecuteAllDpcs+0xf9
80e1cff4 83064e5c 94bb8ce4 00000000 00000000 nt!KiRetireDpcList+0xd5
80e1cff8 94bb8ce4 00000000 00000000 00000000 nt!KiDispatchInterrupt+0x2c
83064e5c 00000000 0000001a 00d6850f bb830000 0x94bb8ce4
iastor.sys, which is Intel Matrix Storage driver, looks good enough but yet run Intel Driver Update Utility to see if it finds any updates for your motherboard including for Intel Matrix Storage and Intel Management Interface:
Intel
Also visit Toshiba support to check for updates for these drivers:
TOSHIBA Universal Camera
pgeffect.sys Mon Jun 22 05:04:57 2009
Toshiba Generic IO & Memory Access, can be a part of a Toshiba utility
QIOMem.sys Mon Jun 15 01:58:21 2009
TOSHIBA Bluetooth
tosporte.sys Tue Jun 16 06:48:40 2009
tosrfbd.sys Thu Sep 24 00:57:10 2009
tosrfcom.sys Tue Jul 28 06:18:06 2009
tosrfec.sys Mon Jun 01 02:58:51 2009
Tosrfhid.sys Tue May 19 21:23:34 2009
TOSHIBA ACPI-Based Value Added Logical and General Purpose Device Driver
TVALZFL.sys Fri Jun 19 06:27:46 2009
TVALZ_O.SYS Mon Jul 13 22:19:21 2009
You have MSE and Microsoft Forefront System, should be OK.
And last but not at all the least, you have DDR3 533 Mhz set as 532Mhz 7-7-7-20-60, while it should be 533 Mhz 7-7-7-20-27 1.5v.
Crash Dump
Microsoft (R) Windows Debugger Version 6.12.0002.633 X86
Loading Dump File [C:\Documents and Settings\XPMUser\My Documents\122810-20202-01.dmp]
Symbol search path is: SRV*C:\Documents and Settings\XPMUser\My Documents\Symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x86 compatible
Built by: 7600.16617.x86fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0x83010000 PsLoadedModuleList = 0x8314f570
Debug session time: Tue Dec 28 01:59:45.028 2010 (UTC - 5:00)
System Uptime: 0 days 0:05:54.588
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck D1, {0, 2, 1, 8947597f}
Unable to load image \SystemRoot\system32\DRIVERS\iaStor.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for iaStor.sys
*** ERROR: Module load completed but symbols could not be loaded for iaStor.sys
Followup: MachineOwner
2: kd> !analyze -v
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 00000000, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000001, value 0 = read operation, 1 = write operation
Arg4: 8947597f, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from 8316f700
Unable to read MiSystemVaType memory at 8314f0c0
 00000000
CURRENT_IRQL:  2
FAULTING_IP:
iaStor+4397f
8947597f 8906            mov     dword ptr [esi],eax
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xD1
PROCESS_NAME:  dwm.exe
TRAP_FRAME:  80e1cdac -- (.trap 0xffffffff80e1cdac)
ErrCode = 00000002
eax=00000000 ebx=86166868 ecx=861668d4 edx=00000000 esi=00000000 edi=861668d4
eip=8947597f esp=80e1ce20 ebp=80e1ce38 iopl=0         nv up ei ng nz ac pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010296
iaStor+0x4397f:
8947597f 8906            mov     dword ptr [esi],eax  ds:0023:00000000=????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from 8947597f to 83048b7b
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
iaStor+4397f
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  iaStor+4397f
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: iaStor
IMAGE_NAME:  iaStor.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4b50ca66
FAILURE_BUCKET_ID:  0xD1_iaStor+4397f
Drivers
start    end        module name
83a13000 83a5b000   ACPI     ACPI.sys     Mon Jul 13 19:11:11 2009 (4A5BBF0F)
902e0000 9033a000   afd      afd.sys      Mon Jul 13 19:12:34 2009 (4A5BBF62)
923cd000 923df000   AgileVpn AgileVpn.sys Mon Jul 13 19:55:00 2009 (4A5BC954)
8961b000 89624000   amdxata  amdxata.sys  Tue May 19 13:57:35 2009 (4A12F30F)
895e5000 895ee000   atapi    atapi.sys    Mon Jul 13 19:11:15 2009 (4A5BBF13)
895ee000 89611000   ataport  ataport.SYS  Mon Jul 13 19:11:18 2009 (4A5BBF16)
93b30000 93b7d000   ATMFD    ATMFD.DLL    Wed May 26 23:49:36 2010 (4BFDEBD0)
83aba000 83ac5000   BATTC    BATTC.SYS    Mon Jul 13 19:19:15 2009 (4A5BC0F3)
9203a000 922d3000   bcmwl6   bcmwl6.sys   Thu Jan 21 22:30:34 2010 (4B591BDA)
9021a000 90221000   Beep     Beep.SYS     Mon Jul 13 19:45:00 2009 (4A5BC6FC)
89bd3000 89be1000   blbdrive blbdrive.sys Mon Jul 13 19:23:04 2009 (4A5BC1D8)
8389f000 838a7000   BOOTVID  BOOTVID.dll  Mon Jul 13 21:04:34 2009 (4A5BD9A2)
821a6000 821bf000   bowser   bowser.sys   Mon Jul 13 19:14:21 2009 (4A5BBFCD)
93b10000 93b2e000   cdd      cdd.dll      Mon Jul 13 21:04:18 2009 (4A5BD992)
901cd000 901ec000   cdrom    cdrom.sys    Mon Jul 13 19:11:24 2009 (4A5BBF1C)
91b5f000 91be0000   CHDRT32  CHDRT32.sys  Mon Feb 01 12:13:24 2010 (4B670BB4)
838e9000 83994000   CI       CI.dll       Mon Jul 13 21:09:28 2009 (4A5BDAC8)
89b73000 89b98000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:11:20 2009 (4A5BBF18)
838a7000 838e9000   CLFS     CLFS.SYS     Mon Jul 13 19:11:10 2009 (4A5BBF0E)
923a0000 923a3700   CmBatt   CmBatt.sys   Mon Jul 13 19:19:18 2009 (4A5BC0F6)
83b4b000 83ba8000   cng      cng.sys      Mon Jul 13 19:32:55 2009 (4A5BC427)
83ab2000 83aba000   compbatt compbatt.sys Mon Jul 13 19:19:18 2009 (4A5BC0F6)
923c0000 923cd000   CompositeBus CompositeBus.sys Mon Jul 13 19:45:26 2009 (4A5BC716)
82262000 8226b000   cpuz135_x32 cpuz135_x32.sys Tue Nov 09 08:32:57 2010 (4CD94D89)
90000000 9000d000   crashdmp crashdmp.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
89bbb000 89bd3000   dfsc     dfsc.sys     Mon Jul 13 19:14:16 2009 (4A5BBFC8)
89baf000 89bbb000   discache discache.sys Mon Jul 13 19:24:04 2009 (4A5BC214)
89b62000 89b73000   disk     disk.sys     Mon Jul 13 19:11:28 2009 (4A5BBF20)
91be0000 91bf9000   drmk     drmk.sys     Mon Jul 13 20:36:05 2009 (4A5BD2F5)
897ed000 897fe000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:12:47 2009 (4A5BBF6F)
9000d000 901c0000   dump_iaStor dump_iaStor.sys Fri Jan 15 15:04:54 2010 (4B50CA66)
9102f000 91039000   Dxapi    Dxapi.sys    Mon Jul 13 19:25:25 2009 (4A5BC265)
9190e000 919c5000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 20:48:33 2009 (4AC54DE1)
919c5000 919fe000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:25:25 2009 (4A5BC265)
89658000 89669000   fileinfo fileinfo.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
89624000 89658000   fltmgr   fltmgr.sys   Mon Jul 13 19:11:13 2009 (4A5BBF11)
897e4000 897ed000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:11:14 2009 (4A5BBF12)
89b30000 89b62000   fvevol   fvevol.sys   Fri Sep 25 22:24:21 2009 (4ABD7B55)
89a66000 89a97000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:12:03 2009 (4A5BBF43)
92367000 9236c280   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:16:53 2009 (4A1151B5)
83410000 83447000   hal      halmacpi.dll Mon Jul 13 19:11:03 2009 (4A5BBF07)
91a63000 91a82000   HDAudBus HDAudBus.sys Mon Jul 13 19:50:55 2009 (4A5BC85F)
919fe000 91a08080   HECI     HECI.sys     Thu Sep 17 15:54:12 2009 (4AB293E4)
89bec000 89bff000   HIDCLASS HIDCLASS.SYS Mon Jul 13 19:51:01 2009 (4A5BC865)
923f7000 923fd480   HIDPARSE HIDPARSE.SYS Mon Jul 13 19:50:59 2009 (4A5BC863)
89be1000 89bec000   hidusb   hidusb.sys   Mon Jul 13 19:51:04 2009 (4A5BC868)
82121000 821a6000   HTTP     HTTP.sys     Mon Jul 13 19:12:53 2009 (4A5BBF75)
89b28000 89b30000   hwpolicy hwpolicy.sys Mon Jul 13 19:11:01 2009 (4A5BBF05)
922ef000 92307000   i8042prt i8042prt.sys Mon Jul 13 19:11:23 2009 (4A5BBF1B)
89432000 895e5000   iaStor   iaStor.sys   Fri Jan 15 15:04:54 2010 (4B50CA66)
91039000 9190e000   igdkmd32 igdkmd32.sys Sat Feb 20 11:18:03 2010 (4B800B3B)
9236d000 9238d500   Impcd    Impcd.sys    Wed Feb 10 18:01:10 2010 (4B733AB6)
9238e000 923a0000   intelppm intelppm.sys Mon Jul 13 19:11:03 2009 (4A5BBF07)
82000000 82026000   ipnat    ipnat.sys    Mon Jul 13 19:54:28 2009 (4A5BC934)
92307000 92314000   kbdclass kbdclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
8802f000 88037000   kdcom    kdcom.dll    Mon Jul 13 21:08:58 2009 (4A5BDAAA)
91ac8000 91afc000   ks       ks.sys       Wed Mar 03 22:57:52 2010 (4B8F2FC0)
897c3000 897d6000   ksecdd   ksecdd.sys   Mon Jul 13 19:11:56 2009 (4A5BBF3C)
898f8000 8991d000   ksecpkg  ksecpkg.sys  Thu Dec 10 23:04:22 2009 (4B21C4C6)
922dd000 922ef000   L1C62x86 L1C62x86.sys Mon Feb 22 04:51:37 2010 (4B8253A9)
820a8000 820b8000   lltdio   lltdio.sys   Mon Jul 13 19:53:18 2009 (4A5BC8EE)
82073000 8208e000   luafv    luafv.sys    Mon Jul 13 19:15:44 2009 (4A5BC020)
83816000 8388e000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:06:41 2009 (4A5BDA21)
82068000 82073000   monitor  monitor.sys  Mon Jul 13 19:25:58 2009 (4A5BC286)
92350000 9235d000   mouclass mouclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
89421000 8942c000   mouhid   mouhid.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
83b20000 83b36000   mountmgr mountmgr.sys Mon Jul 13 19:11:27 2009 (4A5BBF1F)
901ec000 90212680   MpFilter MpFilter.sys Tue Sep 14 17:23:59 2010 (4C8FE7EF)
8233a000 82343200   MpNWMon  MpNWMon.sys  Tue Sep 14 17:23:50 2010 (4C8FE7E6)
821bf000 821d1000   mpsdrv   mpsdrv.sys   Mon Jul 13 19:52:52 2009 (4A5BC8D4)
821d1000 821f4000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:32:02 2010 (4B88CA72)
821f4000 8222f000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:32:21 2010 (4B88CA85)
8222f000 8224a000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:32:11 2010 (4B88CA7B)
89611000 8961b000   msahci   msahci.sys   Mon Jul 13 19:45:50 2009 (4A5BC72E)
90273000 9027e000   Msfs     Msfs.SYS     Mon Jul 13 19:11:26 2009 (4A5BBF1E)
83a64000 83a6c000   msisadrv msisadrv.sys Mon Jul 13 19:11:09 2009 (4A5BBF0D)
89798000 897c3000   msrpc    msrpc.sys    Mon Jul 13 19:11:59 2009 (4A5BBF3F)
89ba5000 89baf000   mssmbios mssmbios.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
89b18000 89b28000   mup      mup.sys      Mon Jul 13 19:14:14 2009 (4A5BBFC6)
89803000 898ba000   ndis     ndis.sys     Mon Jul 13 19:12:24 2009 (4A5BBF58)
92000000 9200b000   ndistapi ndistapi.sys Mon Jul 13 19:54:24 2009 (4A5BC930)
820fe000 8210e000   ndisuio  ndisuio.sys  Mon Jul 13 19:53:51 2009 (4A5BC90F)
9200b000 9202d000   ndiswan  ndiswan.sys  Mon Jul 13 19:54:34 2009 (4A5BC93A)
91b4e000 91b5f000   NDProxy  NDProxy.SYS  Mon Jul 13 19:54:27 2009 (4A5BC933)
90371000 9037f000   netbios  netbios.sys  Mon Jul 13 19:53:54 2009 (4A5BC912)
902ae000 902e0000   netbt    netbt.sys    Mon Jul 13 19:12:18 2009 (4A5BBF52)
898ba000 898f8000   NETIO    NETIO.SYS    Thu Apr 08 22:32:21 2010 (4BBE91B5)
8224a000 82255c00   NisDrvWFP NisDrvWFP.sys Tue Sep 14 17:24:12 2010 (4C8FE7FC)
9027e000 9028c000   Npfs     Npfs.SYS     Mon Jul 13 19:11:31 2009 (4A5BBF23)
903f3000 903fd000   nsiproxy nsiproxy.sys Mon Jul 13 19:12:08 2009 (4A5BBF48)
83010000 83410000   nt       ntkrnlmp.exe Fri Jun 18 23:55:07 2010 (4C1C3F9B)
89669000 89798000   Ntfs     Ntfs.sys     Mon Jul 13 19:12:05 2009 (4A5BBF45)
90213000 9021a000   Null     Null.SYS     Mon Jul 13 19:11:12 2009 (4A5BBF10)
820b8000 820fe000   nwifi    nwifi.sys    Mon Jul 13 19:51:59 2009 (4A5BC89F)
90341000 90360000   pacer    pacer.sys    Mon Jul 13 19:53:58 2009 (4A5BC916)
83aa1000 83ab2000   partmgr  partmgr.sys  Mon Jul 13 19:11:35 2009 (4A5BBF27)
83a6c000 83a96000   pci      pci.sys      Mon Jul 13 19:11:16 2009 (4A5BBF14)
83b36000 83b3d000   pciide   pciide.sys   Mon Jul 13 19:11:19 2009 (4A5BBF17)
83b3d000 83b4b000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:11:15 2009 (4A5BBF13)
897d6000 897e4000   pcw      pcw.sys      Mon Jul 13 19:11:10 2009 (4A5BBF0E)
8226b000 82302000   peauth   peauth.sys   Mon Jul 13 20:35:44 2009 (4A5BD2E0)
91bf9000 91bfee00   pgeffect pgeffect.sys Mon Jun 22 05:04:57 2009 (4A3F4939)
91000000 9102f000   portcls  portcls.sys  Mon Jul 13 19:51:00 2009 (4A5BC864)
8388e000 8389f000   PSHED    PSHED.dll    Mon Jul 13 21:09:36 2009 (4A5BDAD0)
923a4000 923ad000   QIOMem   QIOMem.sys   Mon Jun 15 01:58:21 2009 (4A35E2FD)
923df000 923f7000   rasl2tp  rasl2tp.sys  Mon Jul 13 19:54:33 2009 (4A5BC939)
91a82000 91a9a000   raspppoe raspppoe.sys Mon Jul 13 19:54:53 2009 (4A5BC94D)
91a9a000 91ab1000   raspptp  raspptp.sys  Mon Jul 13 19:54:47 2009 (4A5BC947)
91ab1000 91ac8000   rassstp  rassstp.sys  Mon Jul 13 19:54:57 2009 (4A5BC951)
903b2000 903f3000   rdbss    rdbss.sys    Mon Jul 13 19:14:26 2009 (4A5BBFD2)
9025b000 90263000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:01:40 2009 (4A5BCAE4)
90263000 9026b000   rdpencdd rdpencdd.sys Mon Jul 13 20:01:39 2009 (4A5BCAE3)
9026b000 90273000   rdprefmp rdprefmp.sys Mon Jul 13 20:01:41 2009 (4A5BCAE5)
89aeb000 89b18000   rdyboost rdyboost.sys Mon Jul 13 19:22:02 2009 (4A5BC19A)
8210e000 82121000   rspndr   rspndr.sys   Mon Jul 13 19:53:20 2009 (4A5BC8F0)
82302000 8230c000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
89ae3000 89aeb000   spldr    spldr.sys    Mon May 11 12:13:47 2009 (4A084EBB)
8582b000 85895000   spsys    spsys.sys    Mon May 11 12:37:10 2009 (4A085436)
82393000 823e4000   srv      srv.sys      Thu Aug 26 23:31:26 2010 (4C77318E)
82344000 82393000   srv2     srv2.sys     Thu Aug 26 23:30:45 2010 (4C773165)
8230c000 8232d000   srvnet   srvnet.sys   Thu Aug 26 23:30:39 2010 (4C77315F)
9202d000 9202e380   swenum   swenum.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
92314000 9234da80   SynTP    SynTP.sys    Wed Mar 10 21:00:54 2010 (4B984ED6)
8991d000 89a66000   tcpip    tcpip.sys    Sun Jun 13 23:36:59 2010 (4C15A3DB)
8232d000 8233a000   tcpipreg tcpipreg.sys Mon Jul 13 19:54:14 2009 (4A5BC926)
9235d000 92367000   tdcmdpst tdcmdpst.sys Thu Jul 30 04:26:19 2009 (4A71592B)
902a3000 902ae000   TDI      TDI.SYS      Mon Jul 13 19:12:12 2009 (4A5BBF4C)
9028c000 902a3000   tdx      tdx.sys      Mon Jul 13 19:12:10 2009 (4A5BBF4A)
903a2000 903b2000   termdd   termdd.sys   Mon Jul 13 20:01:35 2009 (4A5BCADF)
9202f000 92039200   tosporte tosporte.sys Tue Jun 16 06:48:40 2009 (4A377888)
8202d000 82055000   tosrfbd  tosrfbd.sys  Thu Sep 24 00:57:10 2009 (4ABAFC26)
9037f000 9038ea00   tosrfcom tosrfcom.sys Tue Jul 28 06:18:06 2009 (4A6ED05E)
923bd000 923bf600   tosrfec  tosrfec.sys  Mon Jun 01 02:58:51 2009 (4A237C2B)
82055000 82067280   Tosrfhid Tosrfhid.sys Tue May 19 21:23:34 2009 (4A135B96)
901c0000 901cb100   tosrfusb tosrfusb.sys Tue Feb 02 20:51:59 2010 (4B68D6BF)
93ae0000 93ae9000   TSDDD    TSDDD.dll    unavailable (00000000)
89400000 89421000   tunnel   tunnel.sys   Mon Jul 13 19:54:03 2009 (4A5BC91B)
89ade000 89ae2100   TVALZ_O  TVALZ_O.SYS  Mon Jul 13 22:19:21 2009 (4A5BEB29)
923ad000 923b4000   TVALZFL  TVALZFL.sys  Fri Jun 19 06:27:46 2009 (4A3B6822)
91afc000 91b0a000   umbus    umbus.sys    Mon Jul 13 19:51:38 2009 (4A5BC88A)
83ba8000 83bbf000   usbccgp  usbccgp.sys  Mon Jul 13 19:51:31 2009 (4A5BC883)
9234e000 9234f700   USBD     USBD.SYS     Mon Jul 13 19:51:05 2009 (4A5BC869)
91a09000 91a18000   usbehci  usbehci.sys  Fri Dec 04 01:51:10 2009 (4B18B15E)
91b0a000 91b4e000   usbhub   usbhub.sys   Fri Dec 04 01:51:51 2009 (4B18B187)
91a18000 91a63000   USBPORT  USBPORT.SYS  Mon Jul 13 19:51:13 2009 (4A5BC871)
83bbf000 83be2b80   usbvideo usbvideo.sys Wed Mar 03 23:04:40 2010 (4B8F3158)
83a96000 83aa1000   vdrvroot vdrvroot.sys Mon Jul 13 19:46:19 2009 (4A5BC74B)
90221000 9022d000   vga      vga.sys      Mon Jul 13 19:25:50 2009 (4A5BC27E)
9022d000 9024e000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:25:49 2009 (4A5BC27D)
83ac5000 83ad5000   volmgr   volmgr.sys   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
83ad5000 83b20000   volmgrx  volmgrx.sys  Mon Jul 13 19:11:41 2009 (4A5BBF2D)
89a9f000 89ade000   volsnap  volsnap.sys  Mon Jul 13 19:11:34 2009 (4A5BBF26)
922d3000 922dd000   vwifibus vwifibus.sys Mon Jul 13 19:52:02 2009 (4A5BC8A2)
90360000 90371000   vwififlt vwififlt.sys Mon Jul 13 19:52:03 2009 (4A5BC8A3)
9038f000 903a2000   wanarp   wanarp.sys   Mon Jul 13 19:55:02 2009 (4A5BC956)
9024e000 9025b000   watchdog watchdog.sys Mon Jul 13 19:24:10 2009 (4A5BC21A)
89a97000 89a9f000   wd       wd.sys       Mon Jul 13 19:11:31 2009 (4A5BBF23)
83994000 83a05000   Wdf01000 Wdf01000.sys Mon Jul 13 19:11:36 2009 (4A5BBF28)
83a05000 83a13000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
9033a000 90341000   wfplwf   wfplwf.sys   Mon Jul 13 19:53:51 2009 (4A5BC90F)
93880000 93acb000   win32k   win32k.sys   Tue Aug 31 22:34:29 2010 (4C7DBBB5)
923b4000 923bd000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:19:16 2009 (4A5BC0F4)
83a5b000 83a64000   WMILIB   WMILIB.SYS   Mon Jul 13 19:11:22 2009 (4A5BBF1A)
8208e000 820a8000   WudfPf   WudfPf.sys   Mon Jul 13 19:50:13 2009 (4A5BC835)
Unloaded modules:
8224a000 82262000   parport.sys
    Checksum:  00000000
    ImageSize:  00018000
82001000 82030000   RtsUStor.sys
    Checksum:  00000000
    ImageSize:  0002F000
89b98000 89ba5000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000D000
90009000 901bc000   dump_iaStor.
    Checksum:  00000000
    ImageSize:  001B3000
901bc000 901cd000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00011000
