I received my laptop yesterday - Core i5, 4GB RAM, Windows 7 Professional 64-bit. I proceeded to install some apps from Microsoft and Adobe. Installation went fine and the apps started without problems. As soon as I saw the long list of fonts in Word, I wanted to remove as many of them as I possibly could.
Brought up Fonts panel. Only 10 fonts - 10 ancient, bitmap fonts. What!? I saw and selected many fonts in Microsoft and Adobe apps. The fonts are indeed there, but they are simply not shown - no Segoe, no Cambria, no Corbel, no Constantia, not even Arial and Times New Roman, nothing.
I got nervous and decided to restore Windows all the way back to the starting point. No luck. Same problem.
Today, I created the recovery DVDs from the factory partition. Rebooted from the DVDs to re-image C drive. Set up Windows and created my account. Windows 7 came up fresh. I went straight to the Fonts panel to check. Horror - the same 10 bitmap fonts, and nothing else.
What is going on? The factory-installed Windows 7 has problems showing fonts? What should I do now?
Thanks in advance.
Thanks in advance.
