Windows 7 Windows 7 "battery" problem
cuteberand
Hey i know that it is been posted a bit about this alredy and i have been reading most of it but i guess its timer to bring life to the posts again, while i keep reading and trying more solutions, appreciate all help...
Ok i've had this problem for quiet some time now and done certain things that i hoped would work, first of a little about my problem.
I got a laptop (info about the laptop comes later) with windows 7 ultimate 32 bit, the last weeks i have gotten a message like this:
"plugged in not charging, concider replacing your battery" "there is a problem with your battery so your computer might shut down suddenly" , not suprisingly the laptop do turn off after battery been on 0% for some time , i can get my battery charged to around 40% after days of charging , the battery burns fast as soon as i turn the laptop on.
If i take out the battery and try to start up without battery and only charger in it comes blue lights from the keyboards and for like 1 second it seems like its gonna start but then it stops.
What i have alredy tried is:
-Once there, run the following command: powercfg -setdcvalueindex SCHEME_CURRENT SUB_BATTERY BATACTIONCRIT 0. This changes the current power scheme so that even when Windows 7 thinks the battery is almost out of power, it won’t shut down the PC.
-firstly close ur laptop.Then take out the battery at the bottom and put on youre charger.open youre laptop and then open youre user.then close the laptop and take out the charger.then put the battery back on and then put the charger on and it should work
-Also tried updates, virus scans , driver updates.
So im pretty much stuck at this so help would be appreciated, some basic information that might be useful about my laptop:
OS Name Microsoft Windows 7 Ultimate
Version 6.1.7600 Build 7600
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name CUTEBERAND---PC
System Manufacturer Hewlett-Packard
System Model HP PAVILION DV9000 (GP660EA#UUW)
System Type X86-based PC
Processor Intel(R) Core(TM)2 Duo CPU T7300 @ 2.00GHz, 2001 Mhz, 2 Core(s), 2 Logical Processor(s)
BIOS Version/Date Hewlett-Packard F.58, 16.06.2008
SMBIOS Version 2.4
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume2
Locale Norge
Hardware Abstraction Layer Version = "6.1.7600.16385"
User Name Cuteberand---PC\Cuteberand--
Time Zone W. Europe Daylight Time
Installed Physical Memory (RAM) 2,00 GB
Total Physical Memory 2,00 GB
Available Physical Memory 1,45 GB
Total Virtual Memory 4,00 GB
Available Virtual Memory 3,32 GB
Page File Space 2,00 GB
Page File C:\pagefile.sys
also a battery report....
Power Efficiency Diagnostics Report
Computer Name CUTEBERAND---PC
Scan Time 2007-04-25T22:18:37Z
Scan Duration 60 seconds
System Product Name HP PAVILION DV9000 (GP660EA#UUW)
BIOS Date 06/16/2008
BIOS Version F.58
OS Build 7600
Platform Role PlatformRoleMobile
Plugged In true
Process Count 47
Thread Count 572
Report GUID {14f834c4-2a1a-4cb6-8681-403583b02940}
Analysis Results
Errors
Battery:Last Full Charge (%)
The battery stored less than 40% of the Designed Capacity the last time the battery was fully charged.
Battery ID Hewlett-PackardPrimary
Design Capacity 88800
Last Full Charge 25574
Last Full Charge (%) 28
Warnings
Power Policy:802.11 Radio Power Policy is Maximum Performance (Plugged In)
The current power policy for 802.11-compatible wireless network adapters is not configured to use low-power modes.
CPU Utilization:processor utilization is moderate
The average processor utilization during the trace was moderate. The system will consume less power when the average processor utilization is very low. Review processor utilization for individual processes to determine which applications and services contribute the most to total processor utilization.
Average Utilization (%) 2.01
CPU Utilization:Individual process with significant processor utilization.
This process is responsible for a significant portion of the total processor utilization recorded during the trace.
Process Name System
PID 4
Average Utilization (%) 0.65
Module Average Module Utilization (%)
\SystemRoot\system32\ntkrnlpa.exe 0.35
\SystemRoot\system32\halmacpi.dll 0.16
\SystemRoot\system32\DRIVERS\nvlddmkm.sys 0.06
Information
Platform Timer Resolution:platform Timer Resolution
The default platform timer resolution is 15.6ms (15625000ns) and should be used whenever the system is idle. If the timer resolution is increased, processor power management technologies may not be effective. The timer resolution may be increased due to multimedia playback or graphical animations.
Current Timer Resolution (100ns units) 156000
Power Policy:Active Power Plan
The current power plan in use
Plan Name OEM Power Saver
Plan GUID {a1841308-3541-4fab-bc81-f71556f20b4a}
Power Policy:power Plan Personality (On Battery)
The personality of the current power plan when the system is on battery power.
Personality Power Saver
Power Policy:Video Quality (On Battery)
Enables Windows Media Player to optimize for quality or power savings when playing video.
Quality Mode Optimize for Power Savings
Power Policy:power Plan Personality (Plugged In)
The personality of the current power plan when the system is plugged in.
Power Policy:Video quality (Plugged In)
Quality Mode Balance Video Quality and Power Savings
System Availability Requests:Analysis Success
Analysis was successful. No energy efficiency problems were found. No information was returned.
USB Suspend:Analysis Success
Battery:Battery Information
Serial Number
Chemistry LION
Long Term 1
all help will be highly appreciated thank you.
