mileycyruslove
- Joined
- Aug 21, 2009
- Messages
- 6
- Thread Author
- #1
Hi there
So I have Windows 7 in my computer, and I can't just use the Aero features (including the theme), because it says that my video card driver is not WDDM compatible.
My Video card driver is: Mobile Intel(R) 915GM/GMS,910GML Express Chipset Family
Graphics memory: 128MB
Should I install one another driver? If so, which one? If I try to update, it says that I'm using the latest version of the driver and it's up to date. But it says that I can't use Aero because of my WDDM incompatibility. What should I do? I am REALLY tired and bored with the basic theme (light blue).
Guys, I think that there must be a solution because the Windows doesn't say I can't use Aero. It says the following:
"The current video card may support Aero with a driver that is compliant with the Windows Display Driver Model (WDDM). Contact the manufacturer of your computer or video card for a WDDM-compatible driver".
Please help
Cheers
Please help
Cheers
