Windows 7 Shell problem
shub
Hello,
About 2 days ago I'm having shell problems, the right click menu of the mouse is the little problem.
First i noticed that i coudnt right click on a rar file and then select extract with winrar. The menu of winrar was there but wen i clicked nothing happend, it just didnt do anything. I reinstalled winrar 10 times and still no luck.
Now it also seems that other programs got the same problem with the shell, avast! also doesnt respond wen i click on a file and select scan.
So can somebody please help me! its really annoying and ive been looking on alot of forums but never saw something like this. I dont have any restore option or something, no backup, not planning on a format c and hopes it works the next time. And i didnt do anything funky lately
(forum n10 im posting this, others couldnt help me...à
~Shub
ramu
Please try creating New User Account from Control Panel to eliminate the possibility of your profile facing issues or your computer... :)
reghakr
Try a system restore point if it just occurred
Windows Forum Admin
Microsoft MVP
Hello,
~Shub
Try running the system file checker.. Right-click on command prompt and run as administrator. Then type:
sfc /scannow
press enter.
If it finds any problems it will attempt to repair.. If it doesn't find anything try running a virus/spyware scan..
shub
thanks everyone,
Restoring to the last recovery point isnt a option because it one of 5 months old (then i rather format it all, but i also dont see that as an option).
I made a new user but now i couldn't right click on any file... i can still rightclick on a folder, rar it and then wen i click on the rar file it just doesnt do anything. Same for picture files.
I did the scanning and it said it found stuff that was wrong, fixed it but that didnt help my problem.
Any more solutions?
~Shub
reghakr
Did you install any "tweaking" software?
Or place any redtictions on your computer
shub
#9
Done that nothing changed, i now do recall using a program to disable some right menu options and i guess it was only for windows vista.
When i click on a folder i got the new windows 7 layout, wen i click on a file i got the old windows xp/vista layout (i guess everyone knows what i mean). In windows 7 the icons are seperated with a line from the discription, in windows xp/vista this is not the case.
When i use that first program all the not working shortcuts turn red, and that other one i really dont have a clue how that can help me...
so anyway i can rebuild my shell? :), btw thanks alot for the effords.
~Shub
Windows Forum Admin
Microsoft MVP
#10
Shub, when you installed the os, was it an upgrade or clean install?
shub
#11
It was a clean one, formatted my drive and then installed it, like i said it only changed about a week ago...
Im going to do the os cd thingy, a restor point is going to bring me way to far back so its easier to format it then. I dont really get the powershell thingy, its already installed on windows 7 and it doesnt seem like there is a update for it.
~Shub
EDIT, check the attachment, ive added a image,
  • the right one is the right click on a file
  • the left one is the right click on a folder
Now that looks like its been broken or something :p
reghakr
#12
Did you try Shellmenu or Autoruns?
Post #8
ramu
#13
Check what UPDATES were installed recently which may have caused the issue.. the possibility is there.... its known that updates can cause weird bizzare things...
it an interesting issue guys.. :)
reghakr
#14
Obviously there are going to be different items on a folder of file.
I don't see any problem at all,.
IMHO you should use cascading menus. It looks cluttered.
Windows Forum Admin
Microsoft MVP
#15
I agree with Reghakr, they look fine to me.
