Windows 7 Windows Firewall Not Starting tried everything Help!
banj0chicken
Iv tried everything to get my firewall started I believe the problem started when my Anti virus free trail expired so I was without an Anti virus for a few days. Anyway I now have Avast anti virus installed and Spybot but when I check my firewall, windows update and windows security center they were all disabled and when I try and start them I get an error message screenshots below:
ImageShack® - Online Photo and Video Hosting
Here is what I have tried so far to fix it.
BFE registry Fix
wscsvc registry Fix
MpsSvc registry Fix
WinDefend registry Fix
SFC /SCANNOW in command prompt
CHKDSK in command prompt
net start wscsvc in command prompt
Starting Windows Firewall Service manually in Services.msc
Running Virus scan
Running registry Fix on CCleaner
MikeHawthorne
I don't have a solution for you, I have the same problem in Windows 8 and have never been able to find a fix after months of trying.
I did install Comodo firewall and it works well, I installed only the firewall not the rest of their security system.
At least in Windows 7 it's possible to do a repair install, you can't even do that in Windows 8, without losing all your software.
Repair Install - Windows 7 Help Forums
If you chose to do this and have service pack 1 installed download a install disk that has in included before you do it unless you disk is new enough to already have it.
Mike
