RangerPivot
- Joined
- Oct 28, 2012
- Messages
- 6
- Thread Author
- #1
I swapped out the MB, CPU and memory in my rig. I did not reinstall windows 7. I was pretty impressed that this worked as well as it did but I have one nagging problem... The network upload speed has suffered a lot. It's not just throughput but the initial "connecting" handshake seems to take a while.
For instance, if I go to one of the speed test sites the download is fine. It starts up immediately and is steady at around 20mbs. When this is complete it takes between 10 and 20 seconds for the upload test to start (just says connecting)... and only uploads at .5 to 1mbs. Historically this has been immediate and much faster.
After much searching I found that disabling windows management instrumentation in msconfig restored my upload network connectivity. In a speed test the download didn't change, but after that was complete the upload started immediately and was around 5mbs.
I disabled/re-enabled this several times to make sure that I got the same results.
Is there any way to "fix" WMI without wiping/reinstalling? That's my last resort.
Other info
MB upgrade was from a ASUS p5qse2 to ASUS p8z77-vlk
CPU went from Q9550 to I7 3770K
Troubleshooting went in this order:
bounced router/modem
bypassed router
reinstalled network adapter
disabled/reenabled windows firewall
disabled wmi
Thanks
Other info
bypassed router
disabled wmi
Thanks
