Windows 7 Windows Recovered From An Unexpected Shutdown. Need help
go2agym1
Here is the mini dmp files I have copied so that maybe someone can help me find out why sometimes this computer can not read my harddrive and it freezes or reboots. I have been having this problem for a while now and my wife is even on me now over it happening.
View attachment minidmp file folder.zip
Thank you for any help.
Greg
jcgriff2
Microsoft MVP
Location
New Jersey Shore
Hi Greg. . ..
Bugcheck was 0x7a (,0xc000000e,,) = kernel data could not be read from the page file
ERROR_CODE: (NTSTATUS) 0xc000000e - A device which does not exist was specified.
DISK_HARDWARE_ERROR: [B][COLOR=#ff0000]There was error with disk hardware[/COLOR][/B]
BUGCHECK_STR:  0x7a_c000000e
Run HDD diags - Hard Drive (HDD) Diagnostics - Sysnative Forums
Regards. . .
jcgriff2
Loading Dump File [C:\Users\PalmDesert\AppData\Local\Temp\SAL8D4.tmp\060513-11887-01.dmp]
Symbol search path is: SRV*a:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: 7601.18113.amd64fre.win7sp1_gdr.130318-1533
Machine Name:
Kernel base = 0xfffff800`02e57000 PsLoadedModuleList = 0xfffff800`0309a670
Debug session time: Wed Jun  5 00:10:15.266 2013 (UTC - 4:00)
System Uptime: 4 days 0:59:18.733
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
ERROR: FindPlugIns 8007007b
BugCheck 7A, {fffff6fc40008bb0, ffffffffc000000e, 12543860, fffff88001176c90}
GetPointerFromAddress: unable to read from fffff80003104278
Probably caused by : memory_corruption
Followup: memory_corruption
2: kd> lmnt
fffff800`00ba0000 fffff800`00baa000   kdcom    kdcom.dll    Sat Feb 05 11:52:49 2011 (4D4D8061)
fffff800`02e0e000 fffff800`02e57000   hal      hal.dll      Sat Nov 20 08:00:25 2010 (4CE7C669)
fffff800`02e57000 fffff800`0343d000   nt       ntkrnlmp.exe Mon Mar 18 23:21:42 2013 (5147D9C6)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Sat Nov 20 04:20:43 2010 (4CE792EB)
fffff880`00c5c000 fffff880`00c86000   ataport  ataport.SYS  Sat Nov 20 04:19:15 2010 (4CE79293)
fffff880`00c9a000 fffff880`00ca7000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`00ca7000 fffff880`00cbb000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`00cbb000 fffff880`00d19000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00d19000 fffff880`00dd9000   CI       CI.dll       Sat Nov 20 08:12:36 2010 (4CE7C944)
fffff880`00dd9000 fffff880`00dfb000   tdx      tdx.sys      Sat Nov 20 04:21:54 2010 (4CE79332)
fffff880`00e00000 fffff880`00e09000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e09000 fffff880`00e13000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`00e13000 fffff880`00e46000   pci      pci.sys      Sat Nov 20 04:19:11 2010 (4CE7928F)
fffff880`00e46000 fffff880`00e53000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`00e53000 fffff880`00e68000   partmgr  partmgr.sys  Sat Mar 17 01:06:09 2012 (4F641BC1)
fffff880`00e68000 fffff880`00e7d000   volmgr   volmgr.sys   Sat Nov 20 04:19:28 2010 (4CE792A0)
fffff880`00e7d000 fffff880`00e84000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00e84000 fffff880`00e94000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`00e94000 fffff880`00eae000   mountmgr mountmgr.sys Sat Nov 20 04:19:21 2010 (4CE79299)
fffff880`00eae000 fffff880`00eb7000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00ed0000 fffff880`00f92000   Wdf01000 Wdf01000.sys Wed Jul 25 22:25:13 2012 (5010AA89)
fffff880`00f92000 fffff880`00fa2000   WDFLDR   WDFLDR.SYS   Wed Jul 25 22:29:04 2012 (5010AB70)
fffff880`00fa2000 fffff880`00ff9000   ACPI     ACPI.sys     Sat Nov 20 04:19:16 2010 (4CE79294)
fffff880`01000000 fffff880`0101b000   ksecdd   ksecdd.sys   Fri Jun 01 22:50:23 2012 (4FC97F6F)
fffff880`0101b000 fffff880`0108d000   cng      cng.sys      Fri Aug 24 11:47:16 2012 (5037A204)
fffff880`0108d000 fffff880`0109e000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`0109e000 fffff880`010a8000   Fs_Rec   Fs_Rec.sys   Wed Feb 29 22:41:06 2012 (4F4EEFD2)
fffff880`010a8000 fffff880`010f1000   fwpkclnt fwpkclnt.sys Wed Jan 02 22:06:48 2013 (50E4F5C8)
fffff880`010f7000 fffff880`01122000   nvstor   nvstor.sys   Fri Mar 19 16:45:11 2010 (4BA3E257)
fffff880`01122000 fffff880`01185000   storport storport.sys Thu Mar 10 23:30:23 2011 (4D79A55F)
fffff880`01185000 fffff880`01190000   amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`01190000 fffff880`011dc000   fltmgr   fltmgr.sys   Sat Nov 20 04:19:24 2010 (4CE7929C)
fffff880`011dc000 fffff880`011f0000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01200000 fffff880`013a2000   Ntfs     Ntfs.sys     Fri Apr 12 07:54:36 2013 (5167F5FC)
fffff880`013a2000 fffff880`01400000   msrpc    msrpc.sys    Sat Nov 20 04:21:56 2010 (4CE79334)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Wed Aug 22 11:11:28 2012 (5034F6A0)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Fri Aug 24 11:48:29 2012 (5037A24D)
fffff880`0148b000 fffff880`0149b000   vmstorfl vmstorfl.sys Sat Nov 20 04:57:30 2010 (4CE79B8A)
fffff880`0149b000 fffff880`014c0000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`014c0000 fffff880`014d0000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`014d3000 fffff880`015c5000   ndis     ndis.sys     Wed Aug 22 11:11:46 2012 (5034F6B2)
fffff880`015c5000 fffff880`015ce000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`015ce000 fffff880`015d9000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`015d9000 fffff880`015ea000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`015ea000 fffff880`015f7000   TDI      TDI.SYS      Sat Nov 20 04:22:06 2010 (4CE7933E)
fffff880`01600000 fffff880`01800000   tcpip    tcpip.sys    Wed Jan 02 22:11:48 2013 (50E4F6F4)
fffff880`01800000 fffff880`01830000   CLASSPNP CLASSPNP.SYS Sat Nov 20 04:19:23 2010 (4CE7929B)
fffff880`01830000 fffff880`01853000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`01886000 fffff880`018b0000   cdrom    cdrom.sys    Sat Nov 20 04:19:20 2010 (4CE79298)
fffff880`018b0000 fffff880`018b9000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`018b9000 fffff880`018c0000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`018c0000 fffff880`018e5000   ehdrv    ehdrv.sys    Thu Dec 09 00:29:58 2010 (4D006956)
fffff880`018e5000 fffff880`018ee000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`018ef000 fffff880`0193b000   volsnap  volsnap.sys  Sat Nov 20 04:20:08 2010 (4CE792C8)
fffff880`0193b000 fffff880`01943000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`01943000 fffff880`0197d000   rdyboost rdyboost.sys Sat Nov 20 04:43:10 2010 (4CE7982E)
fffff880`0197d000 fffff880`0198f000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0198f000 fffff880`01998000   hwpolicy hwpolicy.sys Sat Nov 20 04:18:54 2010 (4CE7927E)
fffff880`01998000 fffff880`019d2000   fvevol   fvevol.sys   Wed Jan 23 22:11:24 2013 (5100A65C)
fffff880`019d2000 fffff880`019e8000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`019e8000 fffff880`019f6000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`019f6000 fffff880`019ff000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0264b000 fffff880`02724000   eamonm   eamonm.sys   Thu Dec 09 00:29:20 2010 (4D006930)
fffff880`02724000 fffff880`02751280   usbvideo usbvideo.sys Sat Nov 20 05:44:34 2010 (4CE7A692)
fffff880`02752000 fffff880`0276cc80   usbaudio usbaudio.sys Sat Nov 20 05:43:52 2010 (4CE7A668)
fffff880`0276d000 fffff880`02782000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`02782000 fffff880`0279a000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`03a00000 fffff880`03a4e000   mrxsmb10 mrxsmb10.sys Fri Jul 08 22:46:28 2011 (4E17C104)
fffff880`03a4e000 fffff880`03a72000   mrxsmb20 mrxsmb20.sys Tue Apr 26 22:39:37 2011 (4DB781E9)
fffff880`03a72000 fffff880`03a93000   epfwwfpr epfwwfpr.sys Thu Dec 09 00:26:09 2010 (4D006871)
fffff880`03ad2000 fffff880`03b9b000   HTTP     HTTP.sys     Sat Nov 20 04:24:30 2010 (4CE793CE)
fffff880`03b9b000 fffff880`03bb9000   bowser   bowser.sys   Tue Feb 22 23:55:04 2011 (4D649328)
fffff880`03bb9000 fffff880`03bd1000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`03bd1000 fffff880`03bfe000   mrxsmb   mrxsmb.sys   Tue Apr 26 22:40:38 2011 (4DB78226)
fffff880`04200000 fffff880`0420c000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`0420c000 fffff880`04217000   usbohci  usbohci.sys  Thu Mar 24 23:29:03 2011 (4D8C0BFF)
fffff880`04217000 fffff880`0426d000   USBPORT  USBPORT.SYS  Thu Mar 24 23:29:12 2011 (4D8C0C08)
fffff880`0426d000 fffff880`0427e000   usbehci  usbehci.sys  Thu Mar 24 23:29:04 2011 (4D8C0C00)
fffff880`0427e000 fffff880`0428b000   usbuhci  usbuhci.sys  Thu Mar 24 23:29:03 2011 (4D8C0BFF)
fffff880`0428b000 fffff880`042a8000   usbccgp  usbccgp.sys  Thu Mar 24 23:29:14 2011 (4D8C0C0A)
fffff880`042ac000 fffff880`0432f000   csc      csc.sys      Sat Nov 20 04:27:12 2010 (4CE79470)
fffff880`0432f000 fffff880`0434d000   dfsc     dfsc.sys     Sat Nov 20 04:26:31 2010 (4CE79447)
fffff880`0434d000 fffff880`0435e000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`0435e000 fffff880`04384000   tunnel   tunnel.sys   Sat Nov 20 05:51:50 2010 (4CE7A846)
fffff880`04384000 fffff880`04399000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`04399000 fffff880`043b6000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`043b6000 fffff880`043be000   ASACPI   ASACPI.sys   Sun Mar 27 22:30:36 2005 (42476C4C)
fffff880`043be000 fffff880`043dc000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`043dc000 fffff880`043eb000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`043eb000 fffff880`043fa000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04415000 fffff880`0449e000   afd      afd.sys      Tue Dec 27 22:59:20 2011 (4EFA9418)
fffff880`0449e000 fffff880`044e3000   netbt    netbt.sys    Sat Nov 20 04:23:18 2010 (4CE79386)
fffff880`044e3000 fffff880`044ec000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`044ec000 fffff880`04512000   pacer    pacer.sys    Sat Nov 20 05:52:18 2010 (4CE7A862)
fffff880`04512000 fffff880`04521000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`04521000 fffff880`0453e000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`0453e000 fffff880`04559000   wanarp   wanarp.sys   Sat Nov 20 05:52:36 2010 (4CE7A874)
fffff880`04559000 fffff880`0456d000   termdd   termdd.sys   Sat Nov 20 06:03:40 2010 (4CE7AB0C)
fffff880`0456d000 fffff880`045be000   rdbss    rdbss.sys    Sat Nov 20 04:27:51 2010 (4CE79497)
fffff880`045be000 fffff880`045ca000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff880`045ca000 fffff880`045d5000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`045d5000 fffff880`045e4000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`045e4000 fffff880`045f5000   usbscan  usbscan.sys  Mon Jul 13 20:35:32 2009 (4A5BD2D4)
fffff880`04a00000 fffff880`04a0c000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`04a0c000 fffff880`04a1a000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`04a1a000 fffff880`04a45000   dump_nvstor dump_nvstor.sys Fri Mar 19 16:45:11 2010 (4BA3E257)
fffff880`04a45000 fffff880`04a58000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`04a58000 fffff880`04a66000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04a66000 fffff880`04a72000   usbprint usbprint.sys Mon Jul 13 20:38:18 2009 (4A5BD37A)
fffff880`04a74000 fffff880`04ab2000   1394ohci 1394ohci.sys Sat Nov 20 05:44:56 2010 (4CE7A6A8)
fffff880`04ab2000 fffff880`04ad6000   HDAudBus HDAudBus.sys Sat Nov 20 05:43:42 2010 (4CE7A65E)
fffff880`04ad6000 fffff880`04b2a080   nvmf6264 nvmf6264.sys Thu Aug 12 07:46:06 2010 (4C63DEFE)
fffff880`04b2b000 fffff880`04b87000   HdAudio  HdAudio.sys  Sat Nov 20 05:44:23 2010 (4CE7A687)
fffff880`04b87000 fffff880`04bc4000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`04bc4000 fffff880`04bf7000   nvhda64v nvhda64v.sys Mon Feb 25 00:27:35 2013 (512AF647)
fffff880`04c00000 fffff880`04c2f000   ndiswan  ndiswan.sys  Sat Nov 20 05:52:32 2010 (4CE7A870)
fffff880`04c2f000 fffff880`04c4a000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04c4a000 fffff880`04c64000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`04c64000 fffff880`04c65480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`04c68000 fffff880`04d5c000   dxgkrnl  dxgkrnl.sys  Tue Apr 09 23:28:09 2013 (5164DC49)
fffff880`04d5c000 fffff880`04da2000   dxgmms1  dxgmms1.sys  Tue Apr 09 23:27:15 2013 (5164DC13)
fffff880`04da2000 fffff880`04db2000   CompositeBus CompositeBus.sys Sat Nov 20 05:33:17 2010 (4CE7A3ED)
fffff880`04db2000 fffff880`04dc8000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`04dc8000 fffff880`04dec000   rasl2tp  rasl2tp.sys  Sat Nov 20 05:52:34 2010 (4CE7A872)
fffff880`04dec000 fffff880`04df8000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`04df8000 fffff880`04dfd200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`04dfe000 fffff880`04dfff00   USBD     USBD.SYS     Thu Mar 24 23:28:59 2011 (4D8C0BFB)
fffff880`05600000 fffff880`0565a000   usbhub   usbhub.sys   Thu Mar 24 23:29:25 2011 (4D8C0C15)
fffff880`0565a000 fffff880`0566f000   NDProxy  NDProxy.SYS  Sat Nov 20 05:52:20 2010 (4CE7A864)
fffff880`0566f000 fffff880`05691000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`05693000 fffff880`06174000   nvlddmkm nvlddmkm.sys Sun May 12 15:09:45 2013 (518FE8F9)
fffff880`06174000 fffff880`06195000   raspptp  raspptp.sys  Sat Nov 20 05:52:31 2010 (4CE7A86F)
fffff880`06195000 fffff880`061a0000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`061a0000 fffff880`061e3000   ks       ks.sys       Sat Nov 20 05:33:23 2010 (4CE7A3F3)
fffff880`061e3000 fffff880`061f5000   umbus    umbus.sys    Sat Nov 20 05:44:37 2010 (4CE7A695)
fffff880`061f5000 fffff880`061ff000   dump_diskdump dump_diskdump.sys Fri Apr 22 16:04:32 2011 (4DB1DF50)
fffff880`0820e000 fffff880`082b4000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`082b4000 fffff880`082bf000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`082bf000 fffff880`082f0000   srvnet   srvnet.sys   Thu Apr 28 23:05:35 2011 (4DBA2AFF)
fffff880`082f0000 fffff880`08302000   tcpipreg tcpipreg.sys Wed Oct 03 12:07:26 2012 (506C62BE)
fffff880`08302000 fffff880`0836b000   srv2     srv2.sys     Thu Apr 28 23:05:46 2011 (4DBA2B0A)
fffff880`0864f000 fffff880`086e7000   srv      srv.sys      Thu Apr 28 23:06:06 2011 (4DBA2B1E)
fffff880`086e7000 fffff880`086f0000   ALSysIO64 ALSysIO64.sys Sat Jul 09 20:27:45 2011 (4E18F201)
fffff880`08761000 fffff880`0876c000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff960`000b0000 fffff960`003c7000   win32k   win32k.sys   unavailable (00000000)
fffff960`005e0000 fffff960`005ea000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`006e0000 fffff960`00707000   cdd      cdd.dll      unavailable (00000000)
fffff960`00830000 fffff960`00891000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffffa80`0571b000 fffffa80`05764000   em006_64 em006_64.dat Fri Mar 22 04:50:19 2013 (514C1B4B)
Unloaded modules:
fffff880`0876c000 fffff880`087dd000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`086f0000 fffff880`08761000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01830000 fffff880`0183e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0183e000 fffff880`01848000   dump_storpor
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`01848000 fffff880`01873000   dump_nvstor.
    Checksum:  00000000
    ImageSize:  0002B000
fffff880`01873000 fffff880`01886000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
go2agym1
I was getting this same thing and I went and bought this new hard drive and installed and its still doing the same thing. It seems to run fine and then I will get a critical update and it starts all this. I have ran all the diagnostics on the new hard drive and it is operating fine.
Any other ideas?
Greg
go2agym1
Ok last night I ran seatoolsdos122 and ran the long test and it said It found an error and corrected it, today I ran the bluescreen of death as advised in the last post and I can not get the results to upload here..
Any ideas?
Greg
go2agym1
Yes Seatools found one error and it corrected it and I have the maximum on the HD that can be. The HD was brand new. I may have caused the error when I put it in new and installed everything. So far since the correction of the error it has not froze or rebooted on its own and I have done all updates it has suggested and the speed has increased.
Top Bottom
