- Thread Author
- #1
Hi all,
Well I think the title says enough-> my internet is getting disconnected after 10 minutes because my wireless adapter is disabeling his self..... After it disables I can't enable it by my self at the adapterproperties, so that makes me restarting the pc everytime to just enable the wireless adapter. When I use the direct internetcable from downstairs everything goes fine. I have the windows vista 32-bit driver for my adapter. And installed the clean version of Windows 7 RC on my pc.
Further more I'd disabled the IPv6 protocol for the wireless adapter.
This are my hardware specs:
Motherboard:GigaByte GA-P35-DS4, P35 (ATX, Sound, LAN, SATA II, RAID, 1394)
W-Lan:Asus WL-138g V2 (54Mbps, PCI)
Processor:Intel Core 2 Quad Q6600 (S775, 4x 3,2GHz, 8MB, 1066MHz FSB, B...
Memory:Corsair TWIN2X2048-6400
Videocard:Sparkle GeForce 8800 GTS 320MB DDR3 (PCI-e, 2x DVI, HDTV, SL...
Soundcard:Creative X-Fi Xtreme Gamer
Speakers:Creative Inspire T6100 (5.1, 4x 8W + 18W, 26W)
I'd be reeeaaaally glad to get some tips from you because this issue is getting annoying
