I use a Linksys Wireless-G adapter, having a lot of problems getting it to detect/install the drivers.
In device manager it detects as an unknown device (and both plugging in/unplugging the device has windows make a noise as it should). However when I try to install the driver via device manager - directing it to my CD drive and the drivers folder, it still says it can't find the drivers.
Installing from the disc doesn't seem to work either.
I've been reading a few posts but I don't think others were having the same exact problem. I saw the suggestion to uncheck box 6 in network properties, but I'm not sure what that was referring to. Also router setup - accept anonymous connections and in the Wifi Properties window - conf adapater adv. - 802.11x to long and short.
I looked around a bit and didn't see those options, so maybe those become available after the drivers are activated. I'm really unfamiliar with Win7 (and Vista for that matter) so could use some very specific help.
