SwampYankee
Windows Home Premium 64. my wireless connection drops about twice a day. Sometimes, it takes the wireless router with it. I have a bunch of stuff on the wireless network, but it seems my laptop is the only one causing a problem. My primary card is a intel n-1030, but I've also tried a wireless usb adapter and have the same issue. I have even tried a different router. Same result. updated drivers, flused the DNS. no luck. Here is my ipconfig all and my DNS any help?
Ipconfig /all
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . nnnnnn-PC7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection 3:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter #
2
Physical Address. . . . . . . . . : BC-77-37-4B-F5-83
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection 2:
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 14-FE-B5-AB-CA-1C
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Intel(R) Centrino(R) Wireless-N 1030
Physical Address. . . . . . . . . : BC-77-37-4B-F5-82
Link-local IPv6 Address . . . . . : fe80::ed33:9951:6e1c:53b3%17(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.111(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, May 22, 2012 5:31:10 PM
Lease Expires . . . . . . . . . . : Wednesday, May 23, 2012 5:31:09 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 180123447
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-15-57-AD-AD-14-FE-B5-AB-CA-1C
DNS Servers . . . . . . . . . . . : 167.206.254.2
167.206.254.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : BC-77-37-4B-F5-86
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:24ca:185f:e747:a736(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::24ca:185f:e747:a736%15(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{23D5AFB2-5DCE-4B28-B815-B777CF610A45}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter isatap.{88AEBC71-BCB4-493B-B99E-2CA2994B6742}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Link-local IPv6 Address . . . . . : fe80::5efe:192.168.1.111%27(Preferred)
167.206.254.1
Tunnel adapter isatap.{A9C860EF-05F8-42F6-9AD9-D94EA819043C}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Tunnel adapter isatap.{66E6FBBA-1C93-43AC-8FC7-DA5A19687598}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #5
Tunnel adapter isatap.{C72A8EFD-4D41-4514-8156-6F17E0993FC5}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #6
ipconfig /displaydns
Data Length . . . . . : 8
Section . . . . . . . : Answer
PTR Record . . . . . : xing.com
grafika.com
Record Name . . . . . : grafika.com
Record Type . . . . . : 1
Time To Live . . . . : 86400
Data Length . . . . . : 4
A (Host) Record . . . : 117.102.101.219
grafika.com
No records of type AAAA
tribalfusion.com
Record Name . . . . . : tribalfusion.com
A (Host) Record . . . : 204.11.109.133
tribalfusion.com
Vista Forums
Record Name . . . . . : Vista Forums
Record Type . . . . . : 5
Time To Live . . . . : 10627
CNAME Record . . . . : vistax64.com
iinfo.com
Record Name . . . . . : iinfo.com
A (Host) Record . . . : 219.139.158.59
iinfo.com
howstuffworks.com
Record Name . . . . . : howstuffworks.com
A (Host) Record . . . : 128.31.1.16
howstuffworks.com
soku.com
Record Name . . . . . : soku.com
A (Host) Record . . . : 211.151.146.16
soku.com
istockphoto.com
Record Name . . . . . : istockphoto.com
A (Host) Record . . . : 74.113.152.32
istockphoto.com
centcomm.com
Record Name . . . . . : centcomm.com
A (Host) Record . . . : 199.26.254.66
centcomm.com
22.50.125.123.in-addr.arpa
Record Name . . . . . : 22.50.125.123.in-addr.arpa.
Record Type . . . . . : 12
PTR Record . . . . . : 126.com
20.159.81.80.in-addr.arpa
Record Name . . . . . : 20.159.81.80.in-addr.arpa.
PTR Record . . . . . : cdmworldsoftware.com
61.149.104.189.in-addr.arpa
Record Name . . . . . : 61.149.104.189.in-addr.arpa.
PTR Record . . . . . : f1cd.com
keenspace.com
Record Name . . . . . : keenspace.com
A (Host) Record . . . : 71.96.135.20
keenspace.com
66.65.175.74.in-addr.arpa
Record Name . . . . . : 66.65.175.74.in-addr.arpa.
PTR Record . . . . . : lupa.com
e-kolay.com
Record Name . . . . . : e-kolay.com
A (Host) Record . . . : 157.95.56.15
e-kolay.com
moscowtimes.com
Record Name . . . . . : moscowtimes.com
A (Host) Record . . . : 70.52.56.163
moscowtimes.com
37.107.51.202.in-addr.arpa
Record Name . . . . . : 37.107.51.202.in-addr.arpa.
PTR Record . . . . . : jetsoftware.com
124.17.42.194.in-addr.arpa
Record Name . . . . . : 124.17.42.194.in-addr.arpa.
PTR Record . . . . . : cgi.com
jetsoftware.com
Record Name . . . . . : jetsoftware.com
A (Host) Record . . . : 202.51.107.37
jetsoftware.com
slideshare.com
Record Name . . . . . : SlideShare.com
A (Host) Record . . . : 174.36.28.11
slideshare.com
235.41.51.72.in-addr.arpa
Record Name . . . . . : 235.41.51.72.in-addr.arpa.
PTR Record . . . . . : nrk.no
localhost
Record Name . . . . . : localhost
A (Host) Record . . . : 127.0.0.1
localhost
11.178.9.204.in-addr.arpa
Record Name . . . . . : 11.178.9.204.in-addr.arpa.
PTR Record . . . . . : typepad.com
Ipconfig /all
2
167.206.254.1
erred)
167.206.254.1
grafika.com
grafika.com
tribalfusion.com
tribalfusion.com
Vista Forums
iinfo.com
iinfo.com
howstuffworks.com
howstuffworks.com
soku.com
soku.com
istockphoto.com
istockphoto.com
centcomm.com
centcomm.com
keenspace.com
keenspace.com
e-kolay.com
e-kolay.com
moscowtimes.com
moscowtimes.com
jetsoftware.com
jetsoftware.com
slideshare.com
slideshare.com
localhost
localhost
