Windows 7 Wireless wont auto connect on restart
maccamenzies
Everything working fine with wireless internet and auto connect is enabled however on restarts the wireless wont reconnect i have to do it manually on the icon.
Any ideas?
hey mac...try clicking on the wifi connection on the taskbar. Pull up the desired network and right click on it and go to properties. On the connection tab check "connect automatically when in range"
Thanks for that.Seems i hadto toggle it on....reboot...toggle it off....reboot ... then toggle it on and it worked.!??
Go figure..
Thanks for your help.
Onto the next problem now.
