huungryshark
- Joined
- Dec 8, 2009
- Messages
- 4
- Thread Author
- #1
MY RALINK 3.00.00.0060 802 n/g/b Drahtlos-LAN-USB Adpater (Azure Wave Technologies) always causes a crash from my internet connection and the whole network card itself.
My System is Windows 7 64bit Premium Home.
I tried updating the driver from Ralink corp.
with no success.
After 1-2 hours of downloading internet connection stops, showing the yellow little sign in the taskbar from the Wifi connection.
I can not even open the networkconnection center.
Shuting down the computer also not works , i have to use the power off switch.
Once i was waiting a long time until the computer shuts down from itself, then a blue screen showed up with some "Power" error.
i switched the power management settings off from the WLAN Card, even USB legacy support ist off in the BIOS.
USB Power saving also turned off and Windows 7 Power Management Settings are on HighPower Full Speed.
I really don´t know what to do...with a cable connected to the NVIDIA nForce NetworkingController my DSL Internet connections runs smooth without any problem.
Anyone can help?
regards,
huungryshark
PS: Sorry for crappy english, my german is much better
with no success.
Anyone can help?
regards,
huungryshark
