- Thread Author
- #1
I just bought this computer and am having problems with WMP. I moved all my music and pictures to my ext hd before decommissioning the old computer but can't get them to the new one properly. I'm not the sharpest here so bear with me. I thought the new puter would see the songs and grab them but not so. Apparently when I trasferred them to the ext hd I did so improperly. THey are all there, or at least they were until I did a complete reinstall of windows 7 trying to fix things which made all of them I had managed to get in the library COMPLETELY disappear/delete (all folders empty with correct names). I have roughly 500 cd's ripped to here and when the transfer from the old hd to the ext hd took place they went to it merely under the drive letter then into a folder with the group/artist name, which is around 250 groups/artists total. After the reinstall I apparently ran into the 50 folder library limit again and it wouldn't let ma add anymore to the library. I can live with that if there's a way to make wmp see all my music each time I open it, but I cannot figure out how to do this. I see I can make a new folder with each artist but how will wmp recognize it? If it doesn't then wmp is not worth a s^&t. I mean, have they actually set this up where you can only have 50 groups/artists on your wmp? Surely they aren't so stupid to limit that. If so, I need to find another player and tell MS to kiss it. I have Zune but it's pulling it's stuff from wmp so it's no help either. On top of that, I ran the wmp troubleshooter after I could no longer add more to it and it said "Media library is corrupted" Does that mean it corrupted when I transferred it all to the ext hd or the wmp program is corrupted? I did the reinstall because I thought I might have a bad wmp but it still is the same. As I said, my files are there and playable on the ext hd even if not in the wmp library (except the ones I mentioned). If I have to, I have already resigned myself to the horrible thought of rerippingand deleting the crummy songs with all these if need be, will just take a few months to have enough time to get to it all and would hate like heck to have reformattted the ext hd only to find this all happens the same way again. I would probably be ready to kill someone at that point. So, what do I/can I do and how the heck do I do it?
