Archangel
Honorable Member
- Joined
- Aug 22, 2009
Just wondering if anyone else is having this issue, and if you're not, are you able to reproduce my steps and see if this is a problem for you as well?...
In my case, the crossfading ends the song, then adds 10 seconds of silence to the end of it. The song will end and the next one will begin. No crossfading at all! NOW... This only happens after the second song in any list has begun.
The first song begins, crossfades into the next, but then the second song starts the "silent treatment" at the end of that and every song after that...
I imagine it's just a bug that hasn't been fixed yet, but I'd like to know who else is having this issue. It's not important or anything, just really annoying. I've been having this issue on both bit-versions of the player.
A few notes:
- Open WMP12 (32-bit or 64-bit, doesn't matter)
- Go to "Now Playing"
- Open "Enhancements"
- Go to the "Crossfading/Auto Volume-Leveling tab"
- Turn crossfading on and adjust the bar to at least 5 seconds (10 is the best benchmark)
- Play a song (Note that you will need to wait till the end of the song to notice if the crossfading is working or not.)
A few notes:
- Computer is fully updated including updates from Microsoft Update. All drivers are intact and running correctly. No conflicts.
- Running the 64-bit version of the Limited Signature GA (Same as the regular one, just a fancier cover -- I like to brag about it, sorry)
- W7 was clean installed. Upgrades just cause issues...
