Marios1441
I'm using Womble EasyDVD video DVD burner and all i get is a non-full screen image of full screen 4:3 and 16:9 video files. The image is squeezed to the middle of the screen. Why and what should i do? I can't change to another video DVD Burner as this is the only
Video DVD Burner i found and maybe the only one that supports audio quality of 1500kbps (Linear PCM).The same incredible audio quality as the audio cds.
The issue you are facing with Womble EasyDVD, where the video files are not showing in full screen on a DVD, likely relates to the aspect ratio settings or the way the video files are being converted or burned onto the DVD. Here are some steps you can take to address this issue: 1. Aspect Ratio Settings: - Ensure that the aspect ratio of your project in Womble EasyDVD matches the aspect ratio of your video files. If your video files are in 16:9 widescreen format, set the project in EasyDVD to 16:9 as well to ensure proper display on screen. 2. Output Format and Resolution: - Check the output format and resolution settings in Womble EasyDVD. Ensure that the output settings match the resolution and aspect ratio of your source...
The issue you are facing with Womble EasyDVD, where the video files are not showing in full screen on a DVD, likely relates to the aspect ratio settings or the way the video files are being converted or burned onto the DVD. Here are some steps you can take to address this issue: 1. Aspect Ratio Settings: - Ensure that the aspect ratio of your project in Womble EasyDVD matches the aspect ratio of your video files. If your video files are in 16:9 widescreen format, set the project in EasyDVD to 16:9 as well to ensure proper display on screen. 2. Output Format and Resolution: - Check the output format and resolution settings in Womble EasyDVD. Ensure that the output settings match the resolution and aspect ratio of your source video files to avoid any distortion during playback. 3. Video Conversion: - If the videos are not in the correct aspect ratio, consider converting them to the correct format before burning them to the DVD. You can use video editing software to adjust the aspect ratio or resolution of the videos to match the output settings of Womble EasyDVD. 4. Preview and Test Burns: - Before finalizing the DVD, always preview your project within Womble EasyDVD to ensure the videos are displaying correctly. Additionally, consider doing test burns on rewritable DVDs to verify the output quality and full-screen display before committing to the final burning process. 5. Documentation and Support: - Review the user manual or online documentation for Womble EasyDVD to see if there are specific recommendations or settings related to aspect ratio and video display. You can also reach out to their customer support for assistance if needed. By adjusting the settings, ensuring compatibility between source files and output settings, and conducting test burns, you should be able to resolve the issue with the video files not displaying in full screen on the DVD.
