Ok so i want to upgrade my laptop from 32bit windows 7 RC to 64 bit as i am upgrading from 3gb ram to 4gb duel channel but when i try to launch it i get this message "The version of this file is not compatible with the version of Windows your're running. Check your computer's information to see whether you need x86(32-bit) or x64(64-bit) version of this program, and then contatct the software publisher.
Any help would be apprieated
