Windows 7 Xbox 360 problems.
gallifrey
Hi there.
I use my 360 as a media extender to stream videos from my pc.
I can stream the high def files (*.wmv) however I cant seem to stream xvid/divx it works fine on Vista, however when i point my 360 to the folder where the files are it tells me "no videos found" the videos work fine in media center.
Any ideas?
I think everyone have the same problem, it has been reported, not sure if this is intentional or not.
In the meantime you can rename your *.avi files to *.wmv or *.mp4
