Windows 7 xp mode
reghakr
Just make sure your system has what it takes to run it or it's not going to function properly.. ;)
Funny thing is I had it working on the leakedd build, but when I try to install on the rc, it tells me my operating suystem does not support it and says that dwm is not running, yet it is:confused:
whoosh
Cooler King
Yes had the same problem the official stITE download gave me the same message ! The unoffical stuff worked fine ? Go figure it =wierd daze .
reghakr
Yeah, whoosh,
I recall you pointed me to the correct version and that's what i thought I had run:confused:
Maybe it's time to take a little break from posting for me, that is. Too many burnt out brain cells.;)
I've made ea few dumb mistakes lately and you and Redenight have came along to the rescue.
Thanks man
