Windows 7 Yet another networking issue
ypdmd
Hi -
I seem to be having a similar problem that others have with windows 7 -have gone through the usual issues and none have solved it.
I have a Dell Optiplex 745 -just did a clean install of Home Premium.
Started dropping the internet connection. ipconfig release and renew solves the problem, as does disabling and re-enabling the nework adapter.
I disabled power saving options on the network adapter and gave the machine a static ip.
This did not solve the problem.
I have verizon DSL and a westell router. I can usually log in to the router @ 192.168.1.1, but no internet access. (router reports good connection and another machines on network can access the internet)
Weird thing is - the router says my machine's ip is 0.168.x.x instead of 1.168.x.x
I don't know if this is related to the issue at all. This is getting very frustrating. Any help is appreciated.
Can you just confirm this quote please? The format is wrong - if your address is starting anything but 192.168 . . . you have a problem with address allocation.
ypdmd:
Not exactly sure what you are seeing in so far as what the router is saying since neither of the addresses you have typed above make much since as far as private reserved ip address and NAT.
I suggest you check what your computer thinks it's ip address is when the problem is present and again with everything is working fine, just launch a command prompt and type ipconfig /all examine the information pertaining to your network adapter.
Additionally if we are talking wired ethernet here, you might try adjusting the speed and duplex of your adapter to see if that improves overall performance/reliability.
Type ncpa.cpl into the search or run dialog box and hit enter
Select then right click the problem adapter usually "Local Area Connection(?)" and choose properties, near the top of the properties dialog box you should see a "Configure" Button click that and then select the advanced tab look in the left frame box for something called Speed & Duplex, try experimenting with different value selections from the drop down box on the right, try 100 full, 100 half, 10 full, 10 half. See if any of them help your issue. Reboot after each change to make sure the changes take effect.
I'd focus on the addressing problem first - instead of looking at what address the router has given your pc have a look at the pc itself and see what address it is holding:
Goto programs, accessories, command prompt and enter the command:
ipconfig /all
If you would like any help checking he output you can display it here.
Update: my computer was reporting my ip address as 192.168.1.46
the router was reporting it as 0.168.1.46
I set up static IP - the router is now properly identifying my machine. But the problem is not resolved.
I disabled bonjour and I thought that fixed the problem but it did not.
When the problem occurs, I am able to ping and login to my router, and I can ping machines on my hamachi vpn, but not machines on the internet.
I don't know if this is related, but when I exit configuration of tcp/ip 4 I get
"Warning - Multiple default gateways are intended to provide redundancy on a single network (such as and intranet or the Internet). They will not function properly then the gateways are on two separate, disjoint networks (such as one on your intranet and one on the Internet). Do you want to save this configuration?"
I'm not sure what this is referring to, because I only have one gateway, but I disable IP 6 if that was causing a conflict.
Is it possible that Hamachi is causing the conflict and it is looking for an internet connection through Hamachi? (windows thinks it is an internet gateway?)
Here is my ipconfig
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
Windows IP Configuration
Host Name . . . . . . . . . . . . : Optiplex-745
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom NetXtreme 57xx Gigabit Controlle
r
Physical Address. . . . . . . . . : 00-18-8B-23-B0-B4
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 192.168.1.225(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 8.8.8.8
151.197.0.39
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Hamachi:
Description . . . . . . . . . . . : Hamachi Network Interface
Physical Address. . . . . . . . . : 00-23-C3-06-85-FD
DHCP Enabled. . . . . . . . . . . : Yes
IPv4 Address. . . . . . . . . . . : 5.6.133.253(Preferred)
Subnet Mask . . . . . . . . . . . : 255.0.0.0
Lease Obtained. . . . . . . . . . : Thursday, August 12, 2010 7:32:12 PM
Lease Expires . . . . . . . . . . : Friday, August 12, 2011 7:34:19 PM
Default Gateway . . . . . . . . . : 5.0.0.1
DHCP Server . . . . . . . . . . . : 5.0.0.1
Tunnel adapter isatap.{FC21D309-1E22-4DA2-8ECB-90FBD01F9FAC}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:2c42:3a46:b805:5637(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::2c42:3a46:b805:5637%13(Preferred)
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{92371EFC-66E4-46D4-85CE-2D2C86E4B7C9}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter 6TO4 Adapter:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter
IPv6 Address. . . . . . . . . . . : 2002:506:85fd::506:85fd(Preferred)
Default Gateway . . . . . . . . . : 2002:c058:6301::c058:6301
Thanks for the help.
you are correct, I mistyped it. my ip was 192.168 etc, and the router had me as 0.168 etc. It also had weird characters in the device name - it was calling it "intel adapter" and then gibberish. I switched to static ip, and things seem to be ok now, although the (verizon westell) router still calls my machine a "media adapter" but calls all the other machines "computers." The internet dropouts are still occurring though, see above post.
The router has let me rename the device "computer" but its just weird that I didn't have to do that with any of the other machines on the network
The reference to multiple gateways is probably due to the fact that you have two defined - one for your router and one for your vpn but that shouldn't be a problem. The settings you have for DNS server could be a problem. As you are using static IP addressing (for which you have correctly set the ip address, subnet mask and default gateway) it might be safer to set your DNS address to that of the router instead of the external DNS server addresses - doing this should cause all DNS requests to be sent to the router which it should then automatically forward to the correct DNS server address supplied by your ISP.
151.197.0.39
Try this please... Enable DHCP. Remove the other DNS servers. Set your only DNS server to your router's IP... 192.168.1.1
The DNS you are using is from WAN side of the network. You will not get a routable, IP address inside your own LAN which will likely prevent the router from managing your internet/sharing access.
Thanks for the suggestions, but I only changed to static ip AFTER the problem started, so using an external DNS is not the cause of the problem. In fact, I switched to an external DNS because when the DNS was set to my router, I was not getting access. I switched to static ip because I wanted to be sure that the error was not with dhcp.
Also, if the problem (with the failing internet connection) was DNS, I would still be able to ping an external ip address. But I was not able to do so.
I will try switching back just for the heck of it, but I seriously doubt it is a solution.
And Tater - Why do you say that you cannot use an external DNS? The configuration currently IS working, it is just that the internet connection drops off every so often. And reseting the adapter solves that problem.
