The thread discusses a Windows 7 RTM user's issue with their integrated Realtek ALC880 audio driver constantly reverting to the default Windows driver, causing a "Device cannot start (Code 10)" error. Despite installing the latest driver manually, Windows automatically reinstalls the standard driver, preventing the user from using the updated version. A proposed solution involves manually removing the current driver via Device Manager before installing the new driver, with a suggestion to ensure the driver is downloaded directly from Realtek's official site. Overall, the user seeks a method to stop Windows from auto-reinstalling the default driver to properly use their updated driver.
Keefo
Hi all! :-)
Im currently running the Windows 7 RTM, and im having a little problem with my sound driver!
it keeps installing a standard driver that comes with Windows 7, and i keep getting this message "This device cannot start. (Code 10)"
I have managed to download the latest driver for it, but when i try to manually install it/update driver, it says "the best driver is currently installed"
And the second i uninstall it, it installs it again straight away using the standard drivers that come with Windows 7... is there any way of stopping this?
This is the computer i have Shuttle United Kingdom - Home
The sound card is built in to the motherboard and its a "Realtek ALC880 7.1 channel High Definition
audio"
Any chance someone can help me stop it installing the standard HD Audio driver when i uninstall it, so i can just install the one i have downloaded?
Or have any other solutions?
Cheers!!
Keith
Hello and welcome to the windows7forums.
Try going to Control Panel > Device Manager and remove the present driver.
Now run the setup for the new driver.
Did you get the driver directly from Realtek's site here:
reghakr
