mynd
- Joined
- Jan 20, 2009
- Messages
- 40
- Thread Author
- #1
Hello there,
For those whom might not know this is a fix while installing some software and works perfectly with adobe reader 8.1.3
Solve a problem with Windows 7 beta
An issue with the Customer Experience Improvement Program (CEIP) client in Windows 7 beta is causing Explorer and some MSI-based installers to stop working properly.
To solve this problem, follow these steps:
- Click the Start button Link Removed - Invalid URL, click All Programs, and then click Accessories.
- Right-click Command Prompt, and then click Run as administrator. Link Removed - Invalid URL In the User Account Control window, verify that Program name is Windows Command Processor, and then click Yes.
- In the Administrator: Command Prompt window, type or paste the following text at the prompt:
reg delete HKLM\SOFTWARE\Microsoft\SQMClient\Windows\DisabledSessions /va /f - Press Enter to install the solution.
- If The operation completed successfully displays, close the Administrator: Command Prompt window to complete this procedure. If "ERROR: Access is denied" displays, repeat this procedure from the top, making sure you clicked Run as administrator in step two.
