krym0gen
Well-Known Member
Hello. I have problems with my pc . Bluescrean is online on my windows. After restart he told me this errors on prints u get it. How can resolve this problems ? Thanks!
BugCheck 50, {fffff900c01447a0, 0, fffff9600067dc51, 0}
Probably caused by : cdd.dll ( cdd!CddBitmapHw::Release+31 )
Followup: MachineOwner
Bugcheck 50 can be caused by one or two things,
Bug check 0x50 usually occurs after the...
in order to help you best we need to see the dump files created at the time of the bsod. The thread here has an app which will help you collect the data we need:
If you do not have any dump files (found in the Windows folder in a folder marked 'Minidump') then your system isn't probably configured to produce them. Change your settings like this in order to have created when a bsod occurs:
Open the run application.
Type sysdm.cpl in the run box and click ok.
Look across the top of the system properties box for 'Advanced' and click that.
Look for 'Startup and Recovery' near the bottom and click 'settings'.
Near the bottom you'll see a drop down menu under the heading 'write debugging information'.
In the drop down menu choose ' small memory dump (256KB)'
Under 'small dump directory' make sure it says %SystemRoot%\Minidump.
Click ok and your good to go.
You will still need to wait until you bsod again to have the dump file created but once it does run the app and post the results.
Sorry for my post is first time :D . I uploaded the minidup RAR.
And what about ur settings i did exactly what you said. Well i will see in the future if something will more happen with my pc.
Bug check 0x50 usually occurs after the installation of faulty hardware or in the event of failure of installed hardware (usually related to defective RAM, be it main memory, L2 RAM cache, or video RAM).
Another common cause is the installation of a faulty system service.
Antivirus software can also trigger this error, as can a corrupted NTFS volume.
Reference
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
This also tells me your missing a critical service pack otherwise the above number would 7601 not 7600.
Please install Service Pack 1 as soon as possible:
(look for this download on the above page: windows6.1-KB976932-X64.exe, it's second from the bottom)
If the Service pack won't install run this update tool:
Drivers
dtsoftbus01.sys Fri Jan 13 13:45:46 2012: Daemon Tools driver. Possible BSOD issues in Win7 please uninstall to test.
Please use the motherboard support page to update your drivers:
ASRock > H81M-VG4
Try using the Intel driver update utility for the intel drivers:
There is a chance that your memory may be faulty but see how you get on making the above changes. If the bsod continues post the new dump files after you've updated etc. Do not forget about the service pack as it's critical.
